AMV converter 4.03 and AMV converter 4.00
well i used to use version 4.03 and now i shift to version 4.00 coz version 4.03 fail to create 160x120 resolution where it should be.
is there any advantage in using version 4.03 in sense it give a better image quality? |
COPYCAT, There appears to be no difference in the quality of the image or frame rate between the two versions.
i think all of the verisons are the same. From my experience.. verisons 4.03 and 4.00 all don't play on my player once converted.
the only verison that plays after conversion is verison 3.68. |
version 4.03 doesn't require u to preinstall windows media player 9 which i likely at first. but then it fail to produce to 160X120 full screen which a bit frust. then again i don't know how i got the version 4 works for me, anyway windows media player 9 not bad either just u can't edit the filter setting.
| All times are GMT -7. The time now is 7:23 am. |
