how to safely uninstall the SLD Codec pack?
Old 1st Aug 2006, 10:38 pm
Default how to safely uninstall the SLD Codec pack?
i accidentally install it. i am using win 98 now so this program can't work for me as it only work with win XP.
in add/remove program, can't find the name of the program.
Old 2nd Aug 2006, 5:51 am
COPYCAT, I have not used the SLD Codec Pack but there may be an entry in the Start>Programs menu with an uninstall or a folder in Program Files that has an uninstall.
Old 3rd Aug 2006, 2:04 am
tadad1, there's no shortcut in start>program neither any uninstall program for that codec. now my media players 9 using one of the codec which i want to to get rid of that codec.
Old 7th Aug 2006, 8:15 pm
go to control panel then click add/remove program and then scroll to SLD codec then remove
Old 7th Aug 2006, 10:53 pm
dear on2x,
Well, the installation never work up pretty well, though there's a sld folders inside windows explorer but no program registered inside add/remove program. thats the biggest problem. can't uninstall now.
Old 8th Aug 2006, 3:18 am
Que Que is offline
Default Re: how to safely uninstall the SLD Codec pack?
If I remember right for win98, ops: run "msconfig" (through "start-run"), see if there is any mention of the SLD in the startup program list there, if so uncheck or untick the box for the prog. Also look in the .ini and .bat file there for entries, probably not there but better to check.
You can also run "regedit", (again through start-run), do a search in regedit for SLD, and remove the keys that are found (carefull not to remove any sld from another program).
Last resort is to search for everything with SLD in it, and remove it by hand.
Restart after making changes.
http://netsquirrel.com/msconfig/
Problem with MP2-Audio-codec: no sound (viDrop.55) lca77 Video related 1 20th Jul 2008 2:28 am
Uninstall MP3 Utilities 3.68 Support and How To 8 5th Dec 2006 12:30 am
External USB Battery Pack (60 Hour Portable Power Pack) tadad1 General Discussion 4 19th Nov 2006 5:49 pm
unable to uninstall AMV Converter 3.68 Tommy Support and How To 5 9th Sep 2006 3:55 pm
mp3 tool 4.00 does not uninstall! Support and How To 10 29th May 2006 5:11 am
