-   -   2gb is actually 2gb (http://mympx.org/forum/general-discussion/33984-2gb-actually-2gb.html)
pyro 2nd Aug 2006 5:31 am
2gb is actually 2gb
i got a 2gb player from ebay and it actually is 2gb i have not had a problem with it yet and have filled it up with my music (now converted to wma) but can fill all of it up. witch is great. showing that not all sellers on ebay are selling fakes. there are legit ones to. and also i only had to play 40pounds for mine compaired to buying it in one of the online stores:)
tadad1 2nd Aug 2006 5:44 am
pyro, thats good news, I am sure there are many genuine sellers on ebay we just generally only hear about the bad ones, 40 quid sounds like a pretty good buy as well. Don't forget to backup your firmware for safty and if you get time upload it to site. Enjoy your player :)
pyro 2nd Aug 2006 6:12 am
Re: 2gb is actually 2gb
don't worry already have backuped my firmware and i have used S1RES ro edit the firmware and now the menu looks sweet. will upload my firmware to the site soon aswell
goldenballs 2nd Aug 2006 9:08 am
Have you got a link to the seller?
2nd Aug 2006 10:30 am
soz no i bought it on my mates pc when i was over his house i'll see if i can get a link but don't get your hopes up because he clears his history all the time.
Spawn_20240 2nd Aug 2006 4:38 pm
I have a 4gb thats really 4gb =]
bsaylors 2nd Aug 2006 4:59 pm
Hey Spawn_20240 - have you opened up your player and seen what you have on the inside? Have you loaded up the player to full capacity and played all the songs? The 4GB's dont exist yet, I know someone who has connections with manufacturers do I know directly when they will be out.
Spawn_20240 2nd Aug 2006 5:40 pm
Ive loaded 535mb of music and 2 small vids. It says i have 3.46GB left. I dont think im going to open it soon. =) everything i open breaks.
admin 2nd Aug 2006 7:20 pm
Spawn_20240,
(make sure you backup the files you want to keep first).
Try to FORMAT your player using the "Disk Tool" as part of the MP3 Player Utilities. When you format it, make sure you use "Low" format and on the "partition/encryption" tab at the top, change it to say "0MB" otherwise you might have problems with partitions and encryptions to your disk after the format.
After the low format, check how much disk space is free now. This will give you a much better indication as to how much disk space is on your player.
Spawn_20240 2nd Aug 2006 7:54 pm
i dont know if i want to :roll:
how much gb is ur mp4,
