[solved] Device Switching Failed, reconnect device please!
[solved]
I am tryin to upgrade Frimware.. I already did once i changed the begining with spawn... And im trying to put the end boot spawn and it says Device Switching Failed, reconnect device please! ideaS? |
Spawn_20240
What version of the MP3 Player Utilities are you using? I've found sometimes I get this problem too. I just have to keep retrying. Best thing to do is once you open the upgrade tool, WAIT for a minute to make sure it doesn't 'drop' the device again then do the upgrade. Try not to do the upgrade too quickly otherwise it might drop out during the firmware upgrade which could cause you more problems. Also try restarting your computer as well in case it's a Windows thing. ;). Let me know the result. |
Re: Device Switching Failed, reconnect device please!
Im using
SC85051B 2006/03/17 ACT_V3.535 My pc has been on for 24+ hours :roll: Ill restart and let you know |
That guest post is by me...
I restarted same problem... I noticed that when i formatted my nano i got 2 removable disk showing up in my computer y[f:] -- the one with my files & removable disk (g). I cant open G it says its not formatted. It doesnt affect what files i put on it, but I would like to custimize the frimware some more =p. Im using MP3 Player Utilities 3.68. |
Spawn_20240
Do you have any other versions of the MP3 Utilities installed on your computer? Try plugging your USB cable from your player into another port in your computer instead. Then try using the "Update Tool" and see if you get a disconnect again. If you use the same firmware you had modified with the Spawn bootup image, it should work. Take note of the display that comes up when you open the Update Tool and check to make sure it saids the SAME VERSION of firmware on the player and on the firmware file. |
:shock: ok nice.
I plugged it in the other usb port and it updated !. Thanks.... :oops: now im waiting for spawn interface |
| All times are GMT -7. The time now is 11:29 am. |
