difference between a full format and a quick format?
Old 6th Aug 2006, 11:54 am
Default difference between a full format and a quick format?
Hi,
Been searching the forum, couldn't find the answer to what's the difference between a full format and a quick format? I understand that a quick format retains the firmware. But does full format erase even the firmware and makes one need a full firmware version?
Thanks.
Old 6th Aug 2006, 4:37 pm
jade7, A quick format just formats the drive a full format checks for bad sectors on the drive before formating and takes a lot longer. Formatting your player should not erase your firmware.
Old 7th Aug 2006, 9:36 am
Thanks Tadad1. Much appreciate your reply.
Which low level format software? Full details. 4gb hacked to show 32gb. Skinski Support and How To 33 6th Jul 2009 6:17 am
How to convert videos to MPEG4 (avi) format? Invalid format? makenna29 Video related 2 19th Feb 2009 1:25 am
[solved] format error/wrong video format... isaac556 Support and How To 2 6th Sep 2008 7:14 pm
Full Screen 1.8 AMV without "FORMAT ERROR" tadad1 Video related 44 6th May 2008 12:37 pm
"Press menu key to format press other key to not format genre_rock Support and How To 0 29th Mar 2008 2:05 am
