-   -   UK charger for nano clone (http://mympx.org/forum/general-discussion/34051-uk-charger-nano-clone.html)
goldenballs 7th Aug 2006 10:24 am
Hi dudes,
My nano clone player comes with a usa 2 pin charger which will be no use to me in the uk. I know I can charge it through my usb cable from my laptop but I would like to be able to charge it through the mains. Would a simple travel plug adapter be ok or would I need some sort of device to change the power supply Ac to dc or whatever? I wouldn't want to blow up my player or kill the battery life on it.
Thanks.
7th Aug 2006 10:53 am
Re: UK charger for nano clone
***edit. It might actually be a Jap 2 pin plug***
http://cgi.ebay.co.uk/Brand-New-2GB-...QQcmdZViewItem
Mecki 7th Aug 2006 11:28 am
Originally Posted by goldenballs";p=&quot (Post 7433)
Hi dudes,
Thanks.
I got one for Great Britain and can't use it in Germany. Can you send me a photo of yours. If it is right for Germany we can perhaps exchange. Is it 220/230 V? If your are interested, please send me a PM
With regards from Germany
Mecki
7th Aug 2006 2:04 pm
if its US you could try a shaver adaptor for around 99p :P
goldenballs 8th Aug 2006 11:56 am
Would this work, and just charge it using the usb cable provided with the mp4 player as if it was plugged into my laptop? It wouldn't fry the battery?
http://cgi.ebay.co.uk/3-PIN-USB-TRAV...QQcmdZViewItem
Thanks for your help.
