Problems downloading from the site?
Old 6th Sep 2006, 9:35 pm
vtdkny, I just downloaded it with no problems from here http://www.mympxplayer.org/dload.php...le&file_id=266.
Old 7th Sep 2006, 4:20 pm
nvm i got it.
thanks!
Old 8th Sep 2006, 5:18 am
Crystal
Guest
Posts: n/a
hey i just downloaded mp3 utilities 3.68 but i can uninstall it..i think there's a virus can anybody help me? pls? im so sorry..=(
Old 8th Sep 2006, 5:39 am
Crystal, you may need to try one of the other versions 3.57 or 4.00. I think the virus alert is a misread as the version has been out for about 12 months and the problem has only been happening over the last month or so. you can download the other versions from Downloads\Tools section pages 2 and 3.
Old 8th Sep 2006, 5:51 am
Crystal
Guest
Posts: n/a
huh?? im sorry but i don't understand..err..i downloaded the program already but an error always appears when i try to remove it from the control panel..pls help me im sorry for the trouble..=)
  #16 (permalink)
Old 8th Sep 2006, 6:23 am
Crystal, sorry I misread your post and thought you were having trouble installing it. You will have to uninstall it manually by deleting the program folder, then open regedit and navigate to the following entries
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Uninstall\
You will find a series of subfolders with alpha numeric names like this {7784A172-61F1-445E-8368-601607E0DD22} click on each one until you find the entry related to MP3 Player Utilities 3.68 displayed in the right panel, then delete this folder.
Do the same thing at this address
HKEY_CURRENT_USER\Software\Microsoft\Installer\Pro ducts\
You should now be able to install one of the other versions.
  #17 (permalink)
Old 8th Sep 2006, 2:09 pm
pietrogirardi
Guest
Posts: n/a
Cannot download drivers n.1 for W98 from the drivers section... could you please re-upload? Thanks a lot!
  #18 (permalink)
Old 8th Sep 2006, 2:22 pm
pietrogirardi
You should be able to download it now.
Sorry about that.
I will also upload a THIRD Win98 drivers package in case the two doesn't work.
  #19 (permalink)
Old 9th Sep 2006, 6:08 pm
Guest
Posts: n/a
I tried downloading everything but all of it does not want to download
  #20 (permalink)
Old 9th Sep 2006, 6:12 pm
Guest, Are you getting any error messages? What have you tried to download?
What type of Mp3/Mp4 player do I have + problems downloading arriabelle Support and How To 11 11th Nov 2008 10:20 pm
The firmware is not downloading Zulu007 Firmware 0 21st Apr 2008 1:36 am
problems with site geostar Miscellaneous 3 13th Jan 2008 10:14 pm
The simplest solution to the site slowness problems. geostar Miscellaneous 3 15th Aug 2007 3:33 pm
Downloading Site black_sheep Support and How To 1 11th Sep 2006 5:09 am
