replace battery!!. nieuwe accu!!.
Old 3rd Sep 2006, 1:24 pm
Default replace battery!!. nieuwe accu!!.
I have 2 ipod clone. 1 for my self 2 weeks old and a second one for my (sexy) girlfriend. last night my girlfriend try to charge the battary with the
adaptor for the first time (i change it with my pc usb port itch time so far).
after morning see check her mpy player it is full.
but the mp4 player work very strange like crazy :shock:
so i make it open to see whatt it is :roll:
the battery was +/- 2 mm bigger then normaal and it fit normaly in the mp4
player and pres the << buttem all the time when i put to one piece:shock: :shock:
houw can i fix this? can i buy a new battery
please help
Wich exchange Accu/Battery ? Linuxator Support and How To 1 9th Jun 2008 9:05 am
How to replace or fix a battery dimples78 Support and How To 3 5th Mar 2008 1:53 am
replace battery willyhehe92 General Discussion 35 5th Sep 2007 8:50 pm
How do you replace the battery? mpxguy Support and How To 1 29th Aug 2007 8:28 pm
Battery replace koschris Mods and Themes 1 25th Feb 2007 11:08 pm
