4th Sep 2006, 9:10 pm
Re: lcd setting
darkle supposed to set the EL backlight to halfpower and black is the EL shutdown for powersave.
unfortunately most of the firmwares that implements these aren't functioning or just partially since it is tied to the clock signal of the unit.
meaning you have to set it every time you shut off the power switch.
but not in every case. some of the units does save the settings so you won't have to set yer clock.
