EARBUDS/ EARPHONES
Old 8th Sep 2006, 5:20 pm
Default EARBUDS/ EARPHONES
Can anyone tell me what specs I am interested in when buying earphones for this mp3 player?
I don't know what impedance and all that means and what numbers are better-higher or lower. What numbers do i want to look for?
I see some on ebay that go right in the ears and reduce noise, but they are large money. I want a cheaper set, but not cheap in quality.
Any thought? Thanx.
maceman
Old 8th Sep 2006, 8:15 pm
Default Re: EARBUDS/ EARPHONES
Yo goto best buy
I got a lil adapter that changes the 2.5mm whole to a 3.5mm so u dont need to deal with all the hassle of finding rare 2.5mm head phones
i got the adapter for 7$
or you could stick with the crappy ear phones that come with it
LORNE TO THE RESCUE!!!!!!!!!!!!!1111111111111111111111ONEONEONE
i actually may have helped some1....who would figure
Old 8th Sep 2006, 8:18 pm
Lorne,
Thanks for your suggestion .
Old 9th Sep 2006, 12:57 pm
actually, that is very helpful. I have some other headphones here i could use and didn't realize an adapter would do the trick. Thanx Lorne.
Old 9th Sep 2006, 1:16 pm
http://www.mympxplayer.org/viewtopic.php?t=94
also, this above link was very helpful to me, in case anyone else happens on this thread here.
Old 9th Sep 2006, 1:50 pm
maceman,
Here is a photo of what the adaptor looks like: http://www.mympxplayer.org/album_sho...php?pic_id=103
Hope that helps.
Old 11th Sep 2006, 5:05 am
mine is just a stick but the wire would be helpful... o well
UXCell Earphones xicex General Discussion - Uxcell.com 14 6th Mar 2007 4:57 pm
OVC T20 / T25 earphones michiganjfrog Reviews 0 6th Mar 2007 9:18 am
2.5mm earphones doesn't work A-D Support and How To 6 16th Feb 2007 8:51 am
2.5mm Earphones on Uxcell Anschluzer General Discussion - Uxcell.com 2 26th Jan 2007 8:38 am
In-Ear Earbuds Reviewed tadad1 General Discussion 7 13th Nov 2006 8:37 am
