Upload problems???
Hya.
I just tried to upload some themes but the files dont appear in the theme list section. Is this normal becouse some sort of waithing time untill admin verifies them or what?? |
Re: Upload problems???
Hi there,
There isn't a problem with the uploads, they just needed to be approved by myself firstly before you can see them. I just approved your uploads. I like your XBox theme. Weird though that it's upside down and mirrored however... :). Are you able to include the original Photoshop file as well or something? This is in case others can flip it back and unmirror it please? Other than that, great looking theme! :) |
Yeah I knew that something like that could be the "problem". :)
And to answer ur question I had to flip my images in order for them to be corectly displayed in my player. Sorry 'bout that. I'm currently uplading the "Almost final" version of my theme and I'll make the images like their should be. Also I will include the Corel Photo Paint (sorry, no Photoshop) files in the Final version. Thanks for the compls. :) |
Zephyron
Great work on the theme. It looks very nice. You might want to mention your theme in the [Themes/Mods] section as well. |
| All times are GMT -7. The time now is 1:30 pm. |
