Memory Gone Crazy
For some reason, after I put a new firmwire on my mp4, it split the mp4 into two different partions.
So the one the mp4 reads for music, is only 17MB, and the other one is 979MB, but the mp4 doesnt read the data from that. Can someone please help me?! |
Re: Memory Gone Crazy
Try going to the SYS Tools >> Online Mode, and select Normal Only.
If it still shows the same thing, you can either re-flash back to your original firmware or format your player with Disk Tool. However the latter would completely clear everything from your memory, so backup before proceeding. |
I have a problem with the sony player mp3. Once i had formatted my player by mistake. When i purchased it showed as 997M. Now its showing only 233M. How can i recover back the original Memory.
Can also mail at suryag@motorola.com Regards surya |
surya, I would guess you have a hacked player and your chip is not a 1GB but 256MB. I suggest you remove the back from your player and check the memory chip serial number and make against chip information HERE
Hi
i will check the same and reply with back details |
thanks for the same
I HAVE FORMATTED MY MP4 IT IS SHOWING ONLY 108MB INSTEAD OF 256MB WAT I SHOULD DO
Or else, it could be that your memory chip was a hacked 128MB chip. It would be easier to verify the actual memory size by opening the player and checking the memory chip's numbers. |
| All times are GMT -7. The time now is 3:14 pm. |
