difrnce mp1100
Old 13th Sep 2006, 10:18 am
Default difrnce mp1100
I've bought this mp4 player but the software that it came with doesn't install, the (mini) cd says Windows 98, so i thought that it were only drivers but it has also software on : AMV Converter Tool, AMV Player, MP3 Player Disc Tool and a MP3 Player Update Tool & Soundtool.
I cant find anything about this player on the web, does anyone know where this thing comes from and if i can use other software to make it work like it should?
Old 13th Sep 2006, 11:59 am
Ok, found it already, the MP3 Player Utilities is the same, i even found software with the same versionnumber on the web (Action AMV Tool 3.57), can different firmware be installed on different players?
I found the manufacturer : http://usboem.en.alibaba.com/product..._1526CF__.html
They make a lot of this stuf, didn't know there was this much :shock: http://usboem.en.alibaba.com/group/0.html
Found the driver 3.74
http://www.usboem.com/Download.asp?boardid=19
Old 13th Sep 2006, 1:03 pm
Default Re: difrnce mp1100
glad i could help you
Old 15th Apr 2007, 5:16 am
I have bought This Difrnce MP1100 to, but i have installed the wrong firmware on it, and now it's dead. I can't find the firmware anywhere.Could someone who has this MP3player upload the firmware...please...I really need it... :cry:
Old 15th Apr 2007, 5:45 am
its not a branded player - by that i mean there are other version of this player out there , you probably dont have the one you thought you did have as you described above , your gonna ahve to figure out the original firmware version and flash all firmware for thT VERSION
Old 16th Apr 2007, 5:47 am
I know the version (9.0.50 Wilson co ltd) i found one that works.. but the button configuration is different.I tried many programs from this website but it didn't work, does anyone no another program that works?
Old 7th May 2007, 1:27 am
the problem has been solved!!! I sent it back to Difrnce and they gave me a new one.. so if someone else has the same problem, here is the firmware for DIFRNCE MP1100: DOWNLOAD HERE
:wink:
Old 27th Oct 2007, 12:03 am
:wink:
The download is expired, can you re-publish the file again?
Is this the original version or the version with the wrong configurated buttons?
DIFRNCE mp1510 load prob. mrmadman Dead Players 0 16th Nov 2009 10:18 am
