Ac adaptor for mp4 player
Old 14th Sep 2006, 4:50 pm
Default Ac adaptor for mp4 player
I have just bought this mp4 player for my Granddaughters birthday present
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA%3AIT&rd=1
It can only charge via usb computer connection but she wants an ac adaptor for when she is away. Is it possible to buy one?
She is over the moon with it and wants to learn how to use all the functions on it so we are busy reading all the info on this wonderful site as the manual is rubbish.
My other two Granddaughters want one for Christmas. Should I buy more of these or go for a different version.
Any advice would be appreciated.
Thanks for reading. Mrs P
Old 14th Sep 2006, 6:22 pm
Betty P
You could try contacting the seller as he may be able to supply you with one and I have also heard they are available on ebay the trouble is finding one to suit a UK socket. They can also be a little unreliable as some members have reported they have shortcircuit or damage their players.
Most of these players are quite standard and perform in roughly the same way even though they may look different. If you are happy with the player you have bought and the seller then buying the same player for your other granddaughters is possibly a safe move or you could try a player that comes with an AC adapter\charger included.
Old 15th Sep 2006, 3:19 pm
Default Re: Ac adaptor for mp4 player
Thnx tadad. Sound advice. Am waiting reply from supplier
Charger adaptor pepe Support and How To 3 27th Jun 2006 9:04 am
