16th Sep 2006, 1:38 am
Re: battery status
you probably have same pictures for status 9,8 and 7,6,5,4,3,2,1, and 0. You should backup your firmware and then check icons for battery status. Then assign correct icons for every status (You can find icons at some themes in DOwnload section, for example Spawn Theme).
