BZZZ noise
Old 17th Sep 2006, 12:18 am
Default BZZZ noise
:idea:
Hello to everybody!
First of all, I'm so sorry about my bad english, I hope to explain correctly what I have to ask! :shock:
I've just bought in ebay a 1,5" MP4 model, 2 gb, it seems work correctly, but I can hear some "bzzz" noise when nothing is playing, it seems an hard disk noise who is looking for files. Maybe this noise is always on, also during playing music. Is it normal or it's only bad luck?
Thanks! :P
Old 17th Sep 2006, 12:43 am
Ruggenet, Is the noise coming from your player or through your earphones. If you can try a different set of earphones to rule out that they are not faulty.
Old 17th Sep 2006, 12:59 am
Default Re: BZZZ noise
Hi tadad,
unfortunately I tried other hearphones, including original ipod's, and the matter does not disappear! I noted that pulling the jack a little bit this "bzzzz" disappear for a while, but it's difficult to find the right position, and anyway it could not stay in this position forever! Could I put some (I don't know how to say...) "electric contacts reactivator spray liquid" ? Maybe it's useless...or dangerous!
Old 17th Sep 2006, 1:22 am
Originally Posted by Ruggenet";p=&quot View Post
Hi tadad,
From what you said about moving the position of the plug and the sound disappears, seems like it's some loose solder contact at the earphone socket with the board.
It's better to contact your seller for a replacement set.
Old 17th Sep 2006, 1:29 am
Hi Lattesurf!
I bought this player on ebay, and the seller have already replaced it because he sent me 1gb model instead 2gb! :x I can't face the shipment charges again! Too expensive I have to find another solution...anyway it's not too boring this bzzzz...other solutions are welcome!!! Thanks!
Old 17th Sep 2006, 1:43 am
My last problem with my player was of similar kind with yours. Only 1 side of the earphone had sound, and if i moved the earphone jack out abit from the socket, both sides have sound. Turned out to be a broken solder and some slight soldering solved it completely.
Well, if you are comfortable with soldering, you could try troubleshooting the board.
The earphone socket has 5 pins soldered to the board, you need to check if these 5 pins are securely soldered down to the board. There might be cracks or broken solder causing the "buzzing" sound you are hearing.
A way of testing the solder conectivity is to turn the player on while it is opened and using a small screwdriver or anything small and metallic to "short" or touch the solder point that you suspect is cracked/broken. You may need to move the screwdriver abit around the solder to check it. If the sound suddenly sounds normal, you have found the broken contact. And you can proceed to solder the contact back.
But only perform these steps if you are comfortable with such "un-orthodox" electronics troubleshooting methods. Else find someone who is good at electronics to do these steps for you.
Good luck.
Old 17th Sep 2006, 1:50 am
Ruggenet. It could be a faulty socket or a soldering fault a mobile phone repair outlet may be able to help.
Old 17th Sep 2006, 1:56 am
Ok, thanks to all of you!
I understood it's an hardware matter, I'll try to find someone who can help me!
Ciao to everybody!
Noise Problem Psyfurius Support and How To 7 10th Jan 2009 7:35 am
Static buzzing noise that never goes away eello123 Support and How To 5 4th Sep 2007 9:07 pm
MP4 Background Noise Darklink Support and How To 5 31st Aug 2007 10:36 pm
Signal to noise ratio for mp3/mp4 players Ivan Mexico General Discussion 0 16th Jul 2007 8:33 am
Noise with new mp3 player karletto66 General Discussion 4 27th Oct 2006 10:57 pm
