Question abaout format task
Old 19th Sep 2006, 7:55 pm
Default Question abaout format task
I bought an mp4 of 2 gb and 1.8". I have to format the disk for what? Only to comprobe that my memory it is about 2 gb? or it has got another consecuence?
Old 19th Sep 2006, 8:37 pm
heber06, If you are not having any problems with your player no need to format. The only thing you should do is backup your firmware with s1fwx which you can download from HERE and there is a guide to using it HERE. That way should you have any problems with your player you can always restore your firmware.
How to convert videos to MPEG4 (avi) format? Invalid format? makenna29 Video related 2 19th Feb 2009 1:25 am
[solved] format error/wrong video format... isaac556 Support and How To 2 6th Sep 2008 7:14 pm
"Press menu key to format press other key to not format genre_rock Support and How To 0 29th Mar 2008 2:05 am
Question about Format...??? Norton Support and How To 1 4th Oct 2006 9:20 pm
difference between a full format and a quick format? jade7 General Discussion 2 7th Aug 2006 9:36 am
