I Need a new Battery for nano clone
Old 20th Sep 2006, 7:23 pm
Default I Need a new Battery for nano clone
i opened my player to fix menu button everytime i pressed menu it would act as left button. Anyways My battery wires detached from board. I ended up cuting the black wire all off. ><_><. I need to buy a new battery where can I?
I belive my frimware is 3.5.35.
here are the battery specs:
YZX
042040
3.7V
260mAh
4.2V
memory info -- is it 4gb?
samsung 625
k9wag.8u1a
pcb0
atj2085w
Old 20th Sep 2006, 8:19 pm
Default Re: I Need a new Battery for nano clone
i assume your memory chip is K9WAG08U1A ? In your other post you mentioned that your player can't save when you reach around 2.3GB? According to the Samsung datasheet, this memory chip is a 2GigaByte memory chip, not 4GB.
Is your battery connectted to the board by 2 wires (red & black)? If so, you can just use a new piece of wire to solder it back.
Old 20th Sep 2006, 8:21 pm
Spawn_20240, Most of these players use a 3.7v Lithium Polymer Battery generally around 200 - 400 mAh. If you do a google search for 3.7 Lithium Polymer Battery you should find online Hobby Stores etc that sell them. Most will provide the dimensions of the battery so find the highest mAh rated battery you can fit in your player. mAh = milliAmp hours the higher the rating the longer it will last between charges.
As for your chip according to the Samsung K9WAG08U1A spec sheet the is 2GB.
2GB Nano Clone -- dead battery? BigTymer Support and How To 2 14th Jan 2008 9:46 pm
Would a 3.7 V mAH Ipod Nano battery work in my nano clone? speedypear Support and How To 8 6th Mar 2007 8:32 pm
1st gen nano clone - Battery charged in 5 min? Impossible speedypear General Discussion 2 2nd Mar 2007 4:34 pm
Nano Clone Battery Life? homegrownpushbikes General Discussion 1 31st Oct 2006 5:57 am
Just got my mp3 nano clone- battery issue? Rocker81 Support and How To 10 10th Jul 2006 5:45 am
