how can i build my own firmware??
hello
can any body tell me or guide me how to build or made my own firmware??? to poeple who have any idea about the subject post replays please or just guide me to other links that talk about the subject.. thank u all! |
Re: how can i build my own firmware??
ok1
If u r refering on changing the firmware so it looks different that you need to check it out the theme part in the download section. U can find tutorials on how to modify four FW in the forum. And if u r reffering to building your own firmware in programmer's sense (coding) that i think that it cannot be done. (well not without extensive codeing knowlege, that is) |
thank u 4 reply
what i mean that build my own firmware becuz i cant find a firmware that works with my MP4 player, till now, i tryed alot of firmwares, no 1 wanna work, so what am refering 2, that if i can change or build some settings in some firmware that can make the screen work as a normal ( its a bleu screen now, no firmware made it work till now) and i guess that a firmware from all i tryed made my butons work and i can play some music and record by the microphone, but all that with the bleu screen.. if ya have any new things to say on that, help me please 2 find my way..! thanx!! |
Hmmm. I recon that you dont have a backup from your firmware file, right? I can only advise u to check your CD that u got with your player. This doesnt seen like much becouse the chances to get the proper firmware from your CD are minimal, but i dont know what else to tell you. Maye some of the more expirienced guys like admin of tadad1 can help you further. It would help if u post the model of your player.
P.S. Just out of curiosity. What happend to your original firmware in the first place? |
i have an MP3/MP4 player with 1.5" screen
its marked as "SONY mmd" but i dont think thats the real mark it has 2 chips 1st: ATJ2085W " u can find it inder the battery when u open the backj side of the player" 2nd: HY27UF081G2M " u can find it under the screen when u open the front side of the player" firmware: 3.5.37 [img=right:19480179af]http://headsun-digital.ec51.com/images/bank/1150162246.jpg[/img:19480179af] thats its photo well 1st i had killed my MP3/MP4 player then i bring it to life by using "dead player recovery guide" now its recovered, then i tried alot of firmwares, from this forum and from S1mp3 website, some of them killed my player, so i recovered it again, and some of them made it had a bleu screen...........sorry havent the player CD. THANK U |
How long ago did you buy it, maybe the seller still has some, and can make a dump from an identical player he still has and email it to you???
Thats a good idea
thank u, i'll try 2 c what i can do............... |
| All times are GMT -7. The time now is 5:19 pm. |
