Samsung and Hynix Nand Flash Sizes and Serial Numbers
Old 29th Dec 2006, 2:47 pm
Default Re: Samsung and Hynix Nand Flash Sizes and Serial Numbers
OK guys...update from Last....
MY exact chip says:
SAMSUNG 646
K9LAG08U0M PCBO
Old 29th Dec 2006, 3:15 pm
johncyz, I just updated the list at the bottom are the density codes. Yours is an "AG" so the chips capacity is 8 Gigabit or 1GB.
Here are a couple of posts that will help you check and fix the problem.
http://www.mympxplayer.org/feedback-...rs-vt2828.html
Old 29th Dec 2006, 4:44 pm
Ok thanks.... I had that wrap around problem, and now it wont let me upload or take corrupted files off. How can I do this? Also, what does firmware do?
Old 29th Dec 2006, 8:31 pm
thanks tatad1 for posting this i was looking for this for a while..thanks it really helped a lot on my research..thnx
Old 29th Dec 2006, 8:38 pm
johncyz, Firmware is the operating system of your player much like Windows is to your PC.
Not a good idea to try upgrading or changing firmware as it is the quickest way to brick your player.
Use "lattesurf's" excellent guide to fix your hacked chip and fix your file problems.
  #16 (permalink)
Old 31st Dec 2006, 12:55 pm
Major Problem...my computer will not recognize the player. How can I get it to?
  #17 (permalink)
Old 31st Dec 2006, 4:57 pm
johncyz, If your player is working ok then try a differrent USB port or the USB cable may be faulty in which case you need to find another to try.
  #18 (permalink)
Old 2nd Jan 2007, 6:42 am
Originally Posted by johncyz";p=&quot View Post
hey all...
I have a Black ipod clone... I checked the Samsung device serial number and the samsung site says that its like a 16 GB card, but the seller sold it as a 2. Also, i tried to put alot of music on it and then it became corrupted...which happens to Fake cards. Why would they put a 16 in...and sell it as a 2 ?
And what is this number? It is on another chip inside the player...with a squiggly I or H above it:ATJ2081N
Hello johncyz, don't worry 16GigaBits are equal to 2GigaBytes (8Bites = 1Byte)
  #19 (permalink)
Old 3rd Jan 2007, 8:44 am
Hit Hit is offline
Somebody know where i can buy an 1gbyte hynix flash chip, so i can upgrade my mp4 player
  #20 (permalink)
Old 13th Jan 2007, 6:45 pm
HY27UT084G2M = 512MBytes
How to read the hynix codes.
http://www.hynix.com/eng/02_products...ND%20Flash.pdf
Remember that it is bits not bytes.
How to Determine the Capacity of a Micron NAND Flash Chip gjtreat Support and How To 2 23rd Dec 2008 12:16 pm
Manufacturer of NAND Flash not be Supported gulego Dead Players 0 20th May 2008 2:55 pm
Want to add nand flash card inside my ipod clone wekiller Support and How To 10 22nd Mar 2008 8:28 pm
NAND flash spyder559 General Discussion - Uxcell.com 0 1st Aug 2007 11:05 pm
Memory Chip Serial Numbers (Found THe Link) ashley_rb General Discussion 0 17th Mar 2007 11:29 am
