Samsung and Hynix Nand Flash Sizes and Serial Numbers
  #21 (permalink)
Old 15th Jan 2007, 10:40 pm
Default Re: Samsung and Hynix Nand Flash Sizes and Serial Numbers
When I click on the Samsung link, at Samsung I cant find the Nand flash sizes and serial numbers.
Does anyone know the link to them for Samsung?
  #22 (permalink)
Old 15th Jan 2007, 11:18 pm
ashley_rb, There is no list of serials and sizes on the Samsung site but you could try a part number search on the site.
http://www.samsung.com/Products/Semi...lash/index.htm
or there is a part number decoder that explains the serial number here:
http://www.samsung.com/Products/Semi...Nand_Flash.pdf
  #23 (permalink)
Old 16th Jan 2007, 9:06 am
perfect. thank you.
  #24 (permalink)
Old 20th Jan 2007, 1:57 am
Default other menings of the characters
and if your techie enough to feed you techie mind.or maybe just a curious person..you may want to look at the other meanings of the characters at the chip..check this one,..
http://www.hynix.com/eng/02_products...ND%20Flash.pdf
  #25 (permalink)
Old 2nd Feb 2007, 1:13 am
My player just arrived today, "4GB" but after formatting is 1GB , for Aus$41 it's still bloody good, will complain but the user is no longer registered so don't know how much luck I'll have.
Have pulled it apart just to double-check, and the only number I can see doesn't correspond to any of those here. It's a Samsung chip, number FEL238BBC. There's one of those "checked on" type markers over the top, so it may be hidden under that, but doesn't appear to be a sticker as such.
Any confirmation would be appreciated. I'm 99% sure it's "only" 1GB, but just want to double-check.
I honestly wouldn't have thought twice about paying what I did for 1GB, 4GB for the same price was just a bonus, but alas that bonus is no more :cry:. Don't know why they don't just sell them as what they are and save everyone the hassles.
PS. Will be posting a guide to converting stuff to AMV on my site in the future, info I couldn't particularly find in one spot, such as flv (youtube etc) to amv, DVD to AMV... In particular, getting the aspect ratios correct.
Don''t f@#k with the Jedi Master, son
  #26 (permalink)
Old 2nd Feb 2007, 1:29 am
RoGuE_STreaK, The number is most likely beneath the QC label. The numbers you have quoted are secondary information to do with batch identification etc.
  #27 (permalink)
Old 2nd Feb 2007, 5:08 pm
Yep, it's an K9K8G08U0M, so 1GB.
At least I was prepared for it, quite happy with a working 1GB for $40, but now to figure out how to complain in a way which may get me some money back to sweeten the deal... :twisted:
  #28 (permalink)
Old 2nd Feb 2007, 9:49 pm
Who did you buy it off?
  #29 (permalink)
Old 2nd Feb 2007, 10:38 pm
mine's not on the list
it's a k9lago8uon
My 2Pac main menu
  #30 (permalink)
Old 2nd Feb 2007, 10:45 pm
pmilladcs, there are heaps of different serials but the two inportant characters are the 4th and 5th on the Samsung chips and the 9th nad 10th on the Hynix chips which denote the memory density which in your case is AG or 16 Gigabit or 2 GigaByte.
How to Determine the Capacity of a Micron NAND Flash Chip gjtreat Support and How To 2 23rd Dec 2008 12:16 pm
Manufacturer of NAND Flash not be Supported gulego Dead Players 0 20th May 2008 2:55 pm
Want to add nand flash card inside my ipod clone wekiller Support and How To 10 22nd Mar 2008 8:28 pm
NAND flash spyder559 General Discussion - Uxcell.com 0 1st Aug 2007 11:05 pm
Memory Chip Serial Numbers (Found THe Link) ashley_rb General Discussion 0 17th Mar 2007 11:29 am
