Samsung and Hynix Nand Flash Sizes and Serial Numbers
  #31 (permalink)
Old 2nd Feb 2007, 11:30 pm
when u say "gigabyte" u mean by memory right?
i think so....just making sure
My 2Pac main menu
  #32 (permalink)
Old 2nd Feb 2007, 11:59 pm
Originally Posted by tadad1";p=&quot View Post
Who did you buy it off?
Bought off buy.mall!, who would appear to be one of the more notorious ones on the blacklist (the things we find out after a purchase...), and who is now no longer a registered user! :roll:
I didn't know a thing about the scam, and didn't delve too deeply into his feedback, just saw the 98.5+% feedback and read a few pages in, seemed OK, but alas... Only came across the scam when looking for info on the avm format.
Also saw when I had the player apart that it only has a 200mAh battery, the manual says 400-500mAh. Though there was nothing in the ad that said about battery size, so... any thoughts on how long 200mAh will play for?
pmilladcs, yep, tadad1 means you have a player with 2gigabytes of memory.
Don''t f@#k with the Jedi Master, son
  #33 (permalink)
Old 3rd Feb 2007, 12:17 am
RoGuE_STreaK , I have a nano clone with a 2oomAh battery and it returns between 5 and 6 hours playtime but this can very depending on what settings you are using. LCD type, EQ settings, volume setting, earphones and how well the firmware is programmed will all effect the battery life. The manuals are generally generic and sent out with many different players as are the mini cd's so it is not unusual for them to contain info that is not relevant to your player.
buy.mall! as you say is one of the bigger scammers so he will be fluent in giving you the run around.
I would suggest be persistant and not give in to his initial offers which will no doubt be measely. If you go via PayPal and eBay be sure to inundate them with pages of information on hacked players, your personal findings and other feed back from his buyers. Just as a test I would also suggest that you visit the petition I set up and copy all the comments left buy those that have signed the petition regarding buy.mall! and even link them to the petition. It will be interesting to see how they respond to this
http://www.petitiononline.com/eBay666/petition.html
  #34 (permalink)
Old 4th Jul 2007, 5:59 pm
Default Re: Samsung and Hynix Nand Flash Sizes and Serial Numbers
My memory chip only has Samsung 8GB. The chip next to it has AK1045. Can anyone tell me the capacity of my memory?
  #35 (permalink)
Old 16th Sep 2007, 2:03 am
tadad1 qrites that :
there are some other serials chips by Hynix:
HY27UFO81G2M (1GigaBit) = 128MB
abderrahman5555 writes>
HY27UFO81G2A (8GigaBit) = 1GB
Meanwhile I go nuts... but at the www.hynix website tadad1 info is the one found
  #36 (permalink)
Old 16th Sep 2007, 2:13 am
zerio , there's probably a typo or confusion due to the large list of numbers.
The Hynix HY27UFO81G2A is a 1Gigabit, 128MegaByte chip.
  #37 (permalink)
Old 16th Sep 2007, 2:33 am
HI Lattersurf
Icould figure out that..thte items and components and numbers ..everything is tiny but my good faith tobuy such a lousy crap.... Ive spent the whole nite up trying tofigureout , studying the memory chiptoknwoHOW TO SHORT CUT... there are about 5 websites..eachof them has a slight difference...oneof them says toshortonly 2pairsof pins.. then plug in the USB...other one says to keep the mp4 allthetime plugged atthe usb.... Im still LOST DIZZY,,,goignto bed now as if I lived there in AU...am exhausted... wish someoen could put intodifferent words how to short...I dotn wanna screw forlifetimewhats leftover frommy chinipod... thou been saearchign a new one..the big issue isSUPPLIER THAT IS RELIABLE...once bitten,twice shy... ok.. if someone coudl give moredetaislabout the short cut process with the scrrew driver or any metalstuff..PLEASE,..go ahead..this point is not clear for poeple who speaks Portuguese as first language..and we are quiet numerous here.
Thanks indeed.
  #38 (permalink)
Old 21st Sep 2007, 4:31 am
My one is HY27UFO81G2M (1GigaBit) = 128MB
Hynix Kor TCB 547A
Which firmware should i use?can anyone plz provide me the link?
  #39 (permalink)
Old 31st Oct 2007, 6:58 am
Hi All
New member just got stuffed with one of these 4gig mp3, my chip is a HY27UT088G2M which is a 1gig so have got on to the seller,be interesting what he has to say I also had 2 virus's on the player as well.
I bought mine before I read up on this scam there must be hundreds of these things being sold can't understand how it is being allowed to go on for so long :shock:
Update on this post and I have done 3 formats with various software that I have and some from the members and my disk is showing 4gig (strange)
Norman
  #40 (permalink)
Old 1st Nov 2007, 7:40 am
Hi
Can someone help why mine is showing 4gig but the chip is a 1gig as my previous post formated 3 times and the last one was done with ANAPOD REINTIALIZER.
Also done with ANAREINT_100.
I have contacted the seller and he wants a screen shot but as I said it is showing 4gig even with the formats.
Norman
How to Determine the Capacity of a Micron NAND Flash Chip gjtreat Support and How To 2 23rd Dec 2008 12:16 pm
Manufacturer of NAND Flash not be Supported gulego Dead Players 0 20th May 2008 2:55 pm
Want to add nand flash card inside my ipod clone wekiller Support and How To 10 22nd Mar 2008 8:28 pm
NAND flash spyder559 General Discussion - Uxcell.com 0 1st Aug 2007 11:05 pm
Memory Chip Serial Numbers (Found THe Link) ashley_rb General Discussion 0 17th Mar 2007 11:29 am
