Samsung and Hynix Nand Flash Sizes and Serial Numbers
  #41 (permalink)
Old 2nd Jan 2008, 2:17 am
thanks
  #42 (permalink)
Old 7th Jan 2008, 1:52 pm
thank you so much
  #43 (permalink)
Old 24th Jan 2008, 5:45 am
Ra! Ra! is offline
Default Chip size vs stamp coded size
Hi all - fantastic site and info.
The utilities are just a breeze to use too - thanks for a great job.
Got a 4GB player for Christmas and the utilities tool showed its real size to be 500MB (4Gbit) that the seller advertised as 4096MB.
Thing is after taking the back off it the chip reads as
K9LAG08U0M which is a 2GB (16Gb) chip.
I've run through the utilities several times & formatted the player enough to convince myself I've done it correctly.
I'd be happy enough with a 2 GB player, but a 0.5 GB... Not considering I bought it to replace a 1GB player. :roll:
Any word on whether chips can be stamped incorrectly ?
Or whether I'm using the correct utilities to determine the true mem size ?
Used : MP3 player utilities 4.05
Cheers
Ra!
  #44 (permalink)
Old 24th Jan 2008, 7:57 am
Ra , when formatting, did you ensure the slider was at the extreme left position for the final formatting?
There is a likely chance of wrong serial number stamping (which are usually sold as product rejects at a cheaper price), or it might be a fake memory chip made by a 3rd party.
  #45 (permalink)
Old 24th Jan 2008, 4:28 pm
Ra! Ra! is offline
Yes Lattesurf
thanks for the response
http://bigpondphotos.com.au/pickup.j...1A1192E071ED9E
pretty sure I did everything correctly from start to finish (double checked)
Guess I will see what the seller says... and if they are willing to remedy their upcoming defamation
Ra!
P.S. the situation with two drives (17MB) + (sizeMB) in the mycomputer-explorer list occurs if you rerun the tool a second time. It didn't occur the first time for me - saw only one drive.
  #46 (permalink)
Old 30th Jan 2008, 5:20 pm
Default Numbers
My NyNix HY27UV088G5M still show 4 GB after 3 formats
NyNix site has a pdf file named "NAND flash.pdf"
It says that the 6th number letter has something to do whit the die
S : SLC + Single Die + S/B
A : SLC + Double Die + S/B
B : SLC + Quadruple Die + S/B
F : SLC + Single Die + L/B
G : SLC + Single Die + L/B
H : SLC + Double Die + L/B
K : SLC + DSP + L/B
T : MLC + Single Die + L/B
U : MLC + Double Die + L/B
V : MLC + Quadruple Die + L/B
W : MLC + DSP + L/B
So my chip has a V -> 8Gb (1GB) X 4 (Quadruple Die) = 4GB
And I have tried to formate the memory 3 times and it still shows 4 GB
Can someone confirm that i have a 4GB player.
/Filuren
Edited -------
The player don't act normal if I fill it with more than 1GB of data. So its a fake.
  #47 (permalink)
Old 21st Feb 2008, 8:37 am
Default Re: Samsung and Hynix Nand Flash Sizes and Serial Numbers
I have a typical Glacier MP4 player that was alleged to have 8GB memory.
The big chip reads: 29F8G08MAA
Any idea what type of memory this is? There appears to be a memorex logo on one side... not sure though...
  #48 (permalink)
Old 11th May 2008, 6:20 am
HI,
I'm new and hope for help.
i have problems with my mp4 player ( http://www.kingzon.de/de/pro/Multimedia/MP4/M4SJ.html ) with 8 GB.
I opened it and the chip says:
Smsung 807
K9LAG08U0M
I didn't find firmaware for the player. i need the orginal firmware, because i have installed the wrong and now it have only 1,89 Gb and when i turn it on, there is only a white display.
things i'v already tryed:
-http://www.mympxplayer.org/viewtopic.php?printertopic=1&t=2400&postdays=0&pos torder=asc&start=0&finish_rel=-10000
-some of this: http://www.mympxplayer.org/actions-9...ware-dc37.html
Please help me!
sorry: bad english - i'm german
How to Determine the Capacity of a Micron NAND Flash Chip gjtreat Support and How To 2 23rd Dec 2008 12:16 pm
Manufacturer of NAND Flash not be Supported gulego Dead Players 0 20th May 2008 2:55 pm
Want to add nand flash card inside my ipod clone wekiller Support and How To 10 22nd Mar 2008 8:28 pm
NAND flash spyder559 General Discussion - Uxcell.com 0 1st Aug 2007 11:05 pm
Memory Chip Serial Numbers (Found THe Link) ashley_rb General Discussion 0 17th Mar 2007 11:29 am
