Question on MP4 player
Old 28th Sep 2006, 6:39 pm
Default Question on MP4 player
Hi. I just bought a "Pearl-z" from uxcell. It was the 2GB version. Does anyone have experience with this model? Is it a non-hacked one? Thanks
Old 28th Sep 2006, 7:05 pm
Default Re: Question on MP4 player
Hoppes, you can't tell whether it is hacked or not by just physically looking at it. The best option is to format it using the MP3 Utilities Disk Tool that came with the player, or use the HP Format Tool. Both of which are downloadable from the downloads section.
Old 28th Sep 2006, 7:10 pm
I am sorry i have put it in wrong area. I havent recieved the player yet. I mainly want to know if this is a good site to buy things from.
Old 28th Sep 2006, 7:21 pm
Hoppes
Check the warranty.
When you get it, save all the files on the player to a folder on your computer, then FORMAT it!
Format it like mad and this will tell you whether it has any hacks done to it.
Old 28th Sep 2006, 7:35 pm
Thank you
8) 2GigaByte Pearl Z --> 1.8 LCD, FM, AMV, Pic, Mic, Ebook, 4-Games 8)
Old 4th Oct 2006, 12:21 am
actually you don't need to fotmat, there is another way, just copy 2GB worth of music on your player (if you don't have 2GB worth of music, just keep copying your music into new files till it fills upto 2GB).
Then run the files off the player through windows, randomly select files, if hacked, then only the files that were copied at the start would work, and not the last ones.
If the majority work, then you don't have a hacked player, if you get error or messages saying that the file is corrupt, then you have a hacked player.
:lol:
Old 4th Oct 2006, 11:35 pm
No worries. I think UXcell.com is a good place to buy things from. They have warranty gaurantee.
BTW, I love their accessories .... always with a unbeatable price.
However, regarding their website, you may need to wait it load (its slow sometimes)
Old 5th Oct 2006, 6:20 pm
Thanks, it shiped so im waiting for it. Will do a review for others when i get it.
Question about my MP4 player spachala General Discussion 10 23rd Dec 2007 11:34 pm
Formatting Player Question Spikeia Support and How To 3 20th Apr 2007 9:00 pm
Question for lattesurf about a player ashley_rb Dead Players 0 14th Apr 2007 9:02 am
MP4 Game Player Question GODVer3 General Discussion 32 13th Feb 2007 12:03 pm
MP4 Player Question MrsCruz Support and How To 1 9th Sep 2006 7:07 pm
