Meizu m6 miniplayer
Old 3rd Feb 2007, 12:11 am
Default Re: Meizu m6 miniplayer
I just ordered one... $235AUD for the m6 + shipping from an Australian ebay seller. I'm pretty excited about it, they look awesome.
Old 3rd Feb 2007, 12:58 am
Thanks for your information. I will order then the Meizu m6 at houseofdap such as am recommended by Tadad1.Many thanks for this. Now still one question where I can find the newest firmware download then so that the playtime of this player is extended and knows you perhaps a good forum which has been focused especially for the Meizu m6 player.
Old 3rd Feb 2007, 1:05 am
mikey, The new firmware is due to be released reportedly around the 18th of February to coincide with Chinese New Year.
Try www.meizume.com for Meizu dedicated forum.
Old 17th Feb 2007, 1:12 am
Hello Tadad1,
do you know how to save photos of my digicam on my meizu player?
and what for cable do i need for this.
Many thanks
Old 17th Feb 2007, 1:59 am
mikey, OTG or "On the Go" file transfer is still under development so it is not possible at present to transfer files from your digicam directly to your M6 you will need to transfer them to a PC then to your player.
When OTG is implemented you will need the Meizu external battery pack pictured below. You will be able to plug the battery pack into your player and then plug your digicam into the battery pack.
  #16 (permalink)
Old 20th Feb 2007, 7:31 am
You could also drag the pictures onto your computer and then into the Meizu's Photos directory as it shows up as another drive in "My Computer"
Originally Posted by mikey";p=&quot View Post
Hello Tadad1,
Many thanks
  #17 (permalink)
Old 20th Feb 2007, 7:41 am
I just received my Meizu player yesterday and seriously this player owns them all.
Great sound quality like the chipods and OWNS my 5.5 Gen Ipod.
It's smaller then I thought it would be and quite cute.
Visual animated EQ bars(real based of frequency not fake) when your playing music with the latest firmware upgrade.
You can easily set wallpaper for the backgrounds.
There are just tons and tons of options.
- Easy to set sleep timer
- Supports Playlist which are really easy to make in winamp
- Video playback is decent but the IPOD's 30 frames per second is still the winner here.
- User Define EQ and presets.
I love this thing
  #18 (permalink)
Old 25th Feb 2007, 6:04 am
I too own the Meizu M6 which they should call the
amazing Meizu M6. Because this thing is the greatest! I love it, it is very versitile, with all of the options. It performs perfectly, and is a great size.
I love my Meizu M6 and can't say to much about it!!
WT
  #19 (permalink)
Old 1st Mar 2007, 11:54 am
I too have the Meizu M6 and it is superb in everyway. If you are thinking of buying a chipod i would just save up and get the M6, you willl not regret spending the extra $120 or so one bit.
  #20 (permalink)
Old 1st Mar 2007, 12:16 pm
Hello Tadad1,
Where can i find firmware S 1.010.3 for the meizu player?
Where to buy Meizu M8 ?? mac_gyver General Discussion 18 12th Mar 2009 11:32 pm
MEIZU M6SL: Freezes at "Miniplayer" screen! balzac308 Dead Players 0 24th Apr 2008 7:21 am
Meizu vs everything else Th3_uN1Qu3 General Discussion 4 4th Jan 2008 2:03 pm
meizu willyhehe92 General Discussion 5 4th Aug 2007 7:19 am
Where to buy meizu M6 lite General Discussion 7 25th Mar 2007 1:50 am
