equalizer
Old 9th Oct 2006, 11:54 pm
Default equalizer
is it possible to edit the equalizer? because the default ones are not quite good
Old 10th Oct 2006, 3:19 am
I don't think so, it would be nice if you could, as i agree, they are pretty useless.
:lol:
Old 10th Oct 2006, 7:02 am
Default Re: equalizer
What? I think that u CAN edit the EQ. Didn't u saw that in the downloads section there is an EQ skin? And by the comments on that post I think it works for all players that have an EQ (Too bad that mine hasn't )
Search the download section. U'll find it in the older downloads.
.....Just pretend that there is a real cool pm here....Till i think of one..... :P
Old 10th Oct 2006, 7:34 am
http://www.mympxplayer.org/new-visua...zer-df161.html
i believe this is waht youre refering to
This is just a skin if i'm not wrong
does anybody know where can i edit the total sturacture of the firmware?
cos i have all the equalizer setting
Old 10th Oct 2006, 7:41 am
Ohh I see what you mean. lol
I dont thing u can change the coding of the FW. Not unless u r a bloody good coder that is.
Old 11th Oct 2006, 2:04 am
maybe i'll try to edit it using hex editor
Old 11th Oct 2006, 2:33 am
XTransbus , it should be able to be done maybe with a hex editor. However, you need to be very such sure of the values that you change, as even a wrong value or character to the hex file, you most likely would kill or hang your player when it is flashed in.
Keep us updated on your progress. Good Luck!
Old 11th Oct 2006, 2:37 am
XTransbus
You can edit the images used for the equalizer. However, they are just 4 images which repeat itself to stimulate an equalizer display and not actually based on the real data from the song.
Hummm, if you can 'redo' the firmware, that would be great! Unfortunately there's not a lot of information about them on the internet to help you out. Looks like the chip manufacturers are quite secretive about it all.... I guess they have to be to protect themselves I guess.
Old 12th Oct 2006, 3:05 am
hmm. i've tried HEX editor and it didn't work, all the characters are unreadable. So i tried notepad since programers sometimes uses notepad to program some files and guess what i found some very familar names
Code:
YS         8      }@SYSBNKA SYS     ,    Z      ]QSYSBNKB SYS     Y    H      պASCII   BIN     }          ȊWLATIN2  BIN               36LANRS   BIN               DLANTK   BIN               1LANIW   BIN     *          6THAI    BIN               \yFONT_GB $$$              pFONT_B5 $$$        6     FONT_JP $$$     <h>LOGO    RES     !   "      #END     RES     %        wDMAIN    AP      '         *bSTANDBY AP      '         e=2USBDISK AP      '   :      G?MUSIC   AP      '   .     [*RECORD  AP      (   x      xVOICE   AP      (         VSETTING AP      )   >      JawFMRADIO AP      -)   >      sy@CONFIG  AP      L)         TESTER  AP      X)         ʼFMRECORDAP      ^)   x      Y$READER  AP      )   x      VIEWPIC AP      )   r      اSAMVDEC  AP      *   t      QTELBOOK BIN     I*   2          G2PIC   BIN     b*         2DEMO    BOX     d*         7GAME    AP      n*   l      u՘eAP_LINE AP      *   x      IAHTELBOOK AP      *   2      3@
Old 12th Oct 2006, 3:09 am
hahaha, i've also found this on my firmware
SDK-ITEM/ACTIONSGongee.ZH vvvvvvWilson Co. Ltd. vvvvvvvvvvvvvvvvS1 Mp4 Player
QiUD_SF321.DRV UD_SF641.DRV UD_SF644.DRV UD_SDMMC.DRV UD_FF321.DRV UD_FF641.DRV UD_FF644.DRV UD_SDMMC.DRV
ok, the file is about several pages long. So it'll take me sometime to crack it though but i can't assure anything because there might be some problems along the way.
since it's a .bin file, anybody have tried to burn it onto a cd?
Modding equalizer.. gaboon Mods and Themes 0 20th Apr 2007 8:18 pm
