[Solved] Full 9.0.43 firmware can be edited?
Old 3rd Nov 2006, 1:56 am
Originally Posted by korn88";p=&quot View Post
My problem with the firmware was that the meter was not accurate enough.. It showed the battery full but then it would fell to only 4lines (from 9).. (almost the same problem that you have)
So I remade the images so that the distribution of the meter was better..
I've seen 3 Nexxtech t9 players, all with the same problem
I have a nano clone with that firmware, and it was showing half battery after a full charge. Fortunately, it came to its senses and is now showing full....
Is there only one version of that firmware? I don't trust the version number, as it doesn't make sense that different chipsets would run the same firmware.
Old 16th Dec 2006, 8:19 am
Default Re: [Solved] Full 9.0.43 firmware can be edited?
Hi Korn88, i have the same player, i have a problem when i try to charge the player with the usb it doesn t charge completely. Please send me a mail to levementepodrido@hotmail.com and tell what is the pronlem with your player. (send the mail in spanish please)
Old 16th Dec 2006, 3:00 pm
Hi, Levemente!
The charger that came with my player does not fully charges battery. IŽll try to fix that changing some electronic components.
If I use my home computer's USB, battery does not charge either.
But at office it works fine.
Both computers are a little bit old, USB 1.x, but it seems that some old USB ports are not able to give enough power.
Maybe that's your case. Try another computer, and even another cable (a friend of mine is got cable issues)
Bye!
Old 17th Dec 2006, 5:26 am
thanks, i will try... If not work i will use my cell phone to charge the battery.
[solved] how to watch videos on my 1.8" mp3 in full scr bob11114 Video related 10 18th Dec 2006 6:56 am
[SOLVED] my mpx player video to be full screen 1.5 inc tkarami Video related 5 27th Nov 2006 9:50 pm
[solved] The battery is not charged full! Yusko Support and How To 5 30th Sep 2006 6:34 am
[solved]disc full error when converting dvd to amv cv1 Video related 5 16th Sep 2006 4:58 pm
[solved] DISK FULL prasanna Video related 24 25th Jun 2006 10:25 pm
