Noise with new mp3 player
Old 27th Oct 2006, 9:44 am
Default Noise with new mp3 player
Hello to all ! I'm a new user...
ops:
I just received a new mp3 player from ebay seller, a 1 giga usb-pen normal "old&cheap" player.
The usual with lcd display, usb-direct-female port and so on...
Firmware 9.0.43
THe problem is that it makes a "Noise" in the background. Similar to a digital "click-click-click..." and seems to be related with display.
When display is "moving" and scrolling the mp3 id-tag the click is louder !
I tried different earphones but the problem is the player...
It's a very disturbing "noise",most in low volume songs.
Someone has seen this "problem" yet ?
Any advice ?
I have already sent a message to seller, i hope it can change this item...
Thanks to all !!!
Old 27th Oct 2006, 1:15 pm
picture plz
Old 27th Oct 2006, 1:30 pm
Default Re: Noise with new mp3 player
This one !
:? Click the image to open in full size.
Old 27th Oct 2006, 5:21 pm
karletto66, It sounds like there is some sort of suppressor problem if you are picking up interference from your LCD. I have one player that does this when trying to use FM Radio but music play is fine. This is most likely a hardware problem and you should try for a replacement.
Old 27th Oct 2006, 10:57 pm
Thanks !
I have mailed seller, hope to have a reply...
See you !
Noise Problem Psyfurius Support and How To 7 10th Jan 2009 7:35 am
Static buzzing noise that never goes away eello123 Support and How To 5 4th Sep 2007 9:07 pm
MP4 Background Noise Darklink Support and How To 5 31st Aug 2007 10:36 pm
BZZZ noise Ruggenet General Discussion 7 17th Sep 2006 1:56 am
FM Transmissor - Pitch Noise Problem guivarrichio Support and How To 4 22nd Jul 2006 4:48 am
