Storage capacities
Old 30th Oct 2006, 11:14 am
Default Storage capacities
Just bought a supposedly 4GB MP4 play via MP3_exp from Hong Kong and on checking inside I find the memory to be Samsung coded K9LAG08U0M. Have tried Samsung site but can find no info on this code. I want to know true capacity to check whether or not I have been had. Checks on Windows XP Home say 4GB but I understand from this site that that might not be a true figure. Can anyone help?
Old 30th Oct 2006, 3:41 pm
Default Re: Storage capacities
Gitus , according to the Samsung datasheet, the K9LAG08U0M is a 2GigaByte memory chip.
You might want to format your player to remove the memory hack.
Old 30th Oct 2006, 4:21 pm
Many Thanks for your answer Surf. Can you direct me to a copy of the Samsung Data sheet?
Old 30th Oct 2006, 5:48 pm
Gitus , the link to the datasheet is Here.
You'll need Adobe to open it.
Old 31st Oct 2006, 1:53 am
:shock: Thanks Surf. But I am still confused for the data sheet shows the code AG as 16GB. Doin my head in. Any way informed seller of my findings and he offerred refund of £5. He can stick it! I will research the average difference of cost between 2/4GB and ddmand that in full. Thanks again
Old 31st Oct 2006, 2:00 am
Gitus , "AG" is the memory density stands for 16Giga (16x10^9), the next 2 numbers "08" stands for 8-bits, so together they mean 16Gigabits. Divide it by 8 (1Byte=8bits), and you'll get 2GigaBytes.
Definitely demand for the extra that you paid for the 4GB over a 2GB model. Good Luck.
Old 1st Nov 2006, 10:08 am
I owe you Surf. Understand now. this is my last reply to MR MP3_exp
Thank you for your email but if wish me to refrain from taking steps to recover my money from Visa then the only deal that I would accept is a refund of GBP £16 less GBP £5 for your original postage cost making a total refund of GBP £11, and in doing this I believe that I am being generous. Why? because you attempted to defraud me by knowingly sending me a hacked 2gb MP3 player instead of the 4GB one that I successfully bid and paid for in good faith. You have betrayed that good faith and I will not allow myself to be cheated.
*/mp3_exp wrote:
sure it's 4gb capacity, u can see the space room if u receive it,thanks! /*
I now know full well that if I returned the existing one (which has a bad battery and therefore I believe that it is not new) I will only receive a Hacked 2GB one again. So half of my payment for half of the item delivered is what you will receive. If I have not heard from with confirmation of my offer in early course then I will proceed as originally notified to you in my email attached below
hope it gees him up
best wishes to you and yours Surf
Mp3 dead, storage alive!! HELP!! RedFox Dead Players 3 3rd Apr 2007 5:40 pm
Samsung Flash Memory Chip Capacities Gitus Miscellaneous 1 7th Nov 2006 10:15 am
Loss of storage capacity tadad1 General Discussion 2 22nd Jul 2006 3:58 am
Storage size different for Actual wtleong Dead Players 13 17th Jul 2006 7:12 am
Mass Storage Babbler_98 Dead Players 33 2nd Jul 2006 5:34 am
