Converting lyrics to .lrc
I want to see the lyrics while um playing the song on my MP4 but it needs to be in .lrc extension so plz can anyone lead me to a program that can make this files or can convert them from .txt to .lrc ??
Re: Converting lyrics to .lrc
SHouSHa, i've found from yahoo some sites that might help you.
.LRC lyrics database: Here and Here. This is a program that you install and search the internet for lrc lyrics Here. And finally, this is a program that allows you to edit the lrc lyrics Here. i've never used the lrc function before and i personally find it no point to. But you can find more information about it by searching for "LRC Lyrics" via search engines. Hope this helps |
I really dont know how to thank you u helped me alot ....
um begining to like this forum already :) :):D :D |
| All times are GMT -7. The time now is 2:13 pm. |
