mp4 player charging
Old 15th Nov 2006, 7:24 pm
Default mp4 player charging
hello everybody
i bought a new mp4 player
so i look in the thing
when i recharge it
it charges till half but doesnt go anymore
how long is battery life so i can check???
Old 15th Nov 2006, 7:46 pm
xeongx, Depending on your battery size you should expect a minimum 4-6 hours continuos music play with all power saving features enabled and about half that for video play.
If you are using a wall charger I suggest try charging your player via usb instead as the wall chargers can be unreliable.
You may need to fully charge and then use your player till flat then fully recharge to get the battery indictor to show a more accurate charge level. After that frequent quick charges are better for Lithium Polymer batteries full cycle recharge\discharge which put a strain on the battery and shorten the life span.
Old 15th Nov 2006, 7:56 pm
so my player isnt hacked or anything?
Old 15th Nov 2006, 8:12 pm
xeongx, I can not say if your player is hacked or not but battery charge problems are not usually an indication of a hacked player.
If you are having problems with file corruption, player restarts, deleting files etc then these are some of the signs of a hacked player.
Old 17th Nov 2006, 2:18 pm
maybe its display problem
how long should i put the player in charge for it so it can charge to max?
Old 17th Nov 2006, 2:58 pm
xeongx, 3 to 4 hours should be enough to fully charge your battery.
Old 17th Nov 2006, 6:06 pm
ohh that is why, all this time i put it max for half hour
XD
Old 17th Nov 2006, 6:30 pm
xeongx, needs a bit more time....
Player not charging kevlow Support and How To 1 4th Oct 2007 10:46 pm
mp3/mp4 player not charging heartlessarchangel Support and How To 9 18th Aug 2007 6:33 am
MP4 player not charging.... myvic Support and How To 5 1st Aug 2007 11:05 pm
Charging Mp4 Player Enprinte Support and How To 1 14th Jun 2006 2:42 am
player on or off charging kaz Support and How To 5 29th May 2006 4:43 am
