MP4 SD85043I FİRMWARE
Old 18th Nov 2006, 1:29 pm
Default MP4 SD85043I FİRMWARE
hi ı need mp4 sd85043ı new firmware.act v3.5.37 1.5 inç please help me this firmware not amv play..frame problem..thanks..
Old 18th Nov 2006, 3:28 pm
denizz74, I do not suggest trying to update your firmware you will most likely kill your player trying to do so.
What problems are you having with your AMV?
What size screen does your player have?
What version of the AMV Converter are you using?
Old 18th Nov 2006, 3:45 pm
thanks..mav tools 4.05
amv frame not good
and 1.5 ınç 128-96
Old 18th Nov 2006, 4:13 pm
denizz74, For a 1.5 you should be using version 3.68 HERE
You should also install the K-Lite Mega Codec Pack if you have not already HERE
Once you have these 2 installed try another conversion.
Old 19th Nov 2006, 8:00 am
thanks, i try
Old 27th Nov 2006, 4:16 pm
Default Re: MP4 SD85043I FİRMWARE
merhaba deniz çözdünmü Problemini ?
Old 3rd Dec 2006, 11:39 am
sadece 3 kişi miyiz ?
Old 3rd Dec 2006, 3:23 pm
Saglık olsun deniz
HELP ME PLEASE FİRMWARE baha24 Firmware 1 19th Nov 2008 8:44 pm
Help me ! FİRMWARE abdurrahmanz Dead Players 1 13th Mar 2008 3:05 am
