Battery
Well like most of you guys I've got ripped of by an Ebay seller that sold me a 4GB which actually is a 1GB, fixed that one but there's something weird about this player, when I play music the background light stays on which mean my battery's life is over within 1 hour ? Anyone else know how to fix this one?
Re: Battery
Sua , to set the background light to turn off, go to
Sys Tools >> Set LCD >> Darkle Here you can set in seconds, the amount of idle seconds before the player turns off the backlight. |
Re: Battery
G*D yes ofcourse i'm such an idiot, thank you lattesurf!
Re: Battery
i rteally do no understand how these guys can get away with a totally fake and hacked player, that fucking fraud
Re: Battery
Well not really because he's paying me back part of my money so it's a fair deal, I managed to repair the player and i'm gonna make an 8GB from it. It's a great player to test things with, it's easy to modify hardware/software.
sua , you said "I managed to repair the player and i'm gonna make an 8GB from it" how can i do that i want to extend my mem. cap. please tell me how
You will need to be able to solder as an expert :) Anyone tried it? |
it dont matter, its FALSE ADVERTISING, and that sir is illigal
Re: Battery
Sua , if your player is running off an Actions ATJ chipset, the maximum you can go is 2GB. As the ATJ only can support upto a maximum of 2GB.
i'll suggest that you identify the chipset and find the datasheet for it. Then see the maximum supported memory size. Else, you would be just dumping your money into the drain if it does not support such a large memory size. |
| All times are GMT -7. The time now is 6:10 am. |
