Help I broke the on off switch
Old 30th Nov 2006, 5:14 pm
Default Help I broke the on off switch
i broke the on off switch on my mp4 player...is there any way i can by pass it
please help
Old 30th Nov 2006, 5:55 pm
brendan1234, If you can manage to get it into an on position you can turn your player on and off by long pressing the play button.
Can you give some more details on "broke" what actually broke?
Old 30th Nov 2006, 6:16 pm
Default Re: Help I broke the on off switch
ok it started off the plastic broke....i opened it up and chipped off the metal connecter that holds it in place....then on the other side of the metal connector...i broke 1 of the three connectors on the board.....
my bad i dont know another word for connector
Old 30th Nov 2006, 6:35 pm
brendan1234, Well as the switch is basically just a circuit breaker you could use a piece of wire and test which 2 connections turn your player on when crossed. Once you identify the 2 points you could join them with solder and the player would be permanantly on and you could then use the play button for on\off.
my vx858le's switch button broke vx858le_ Dead Players 1 1st May 2008 11:03 am
Cover for my mp4 broke off vietnamesetan Support and How To 0 27th Mar 2008 12:36 pm
I broke the screen off, anything I can do? Antz Dead Players 0 13th Oct 2007 11:05 pm
Broke, Dead, and all of the above! gta3dude Dead Players 1 3rd Oct 2006 8:38 pm
plastic screen broke.... magenet General Discussion 3 2nd Jul 2006 8:18 am
