MP3 isn't loaded when I change battery
Old 2nd Dec 2006, 1:52 am
Default MP3 isn't loaded when I change battery
Hello,
my MP3 player (not MP4) without video, it is supplied with AAA battery. When the old battery dies and I insert new battery the player writes ...starting... then ...PRESS ANY KEY... and after I press any key it is turned off, and it repeats again...again and again, until I insert the player in USB slot in the computer. After I pull off the player from the computer it works normally and it turns on normally too. Help how to avoid this situation.
how can i change battery from a ipod clone? Ecege Support and How To 0 6th Jul 2007 6:16 pm
How to change BATTERY for LONGER LIFE!!! d12nv Support and How To 7 1st May 2007 1:47 am
Can you change a Meizu battery? michiganjfrog General Discussion 6 31st Jan 2007 1:52 am
i-Platinum: Can you change the battery? michiganjfrog General Discussion - Uxcell.com 2 12th Jan 2007 9:42 pm
Battery Change rejaul2005 General Discussion 16 20th Sep 2006 2:10 pm
