what batteries fit in Super I-Platinum 1.8inch 2GB
Old 6th Dec 2006, 11:55 pm
Default what batteries fit in Super I-Platinum 1.8inch 2GB
I am desperatly searching for a new battery replacement for my Super I-Platinum 1.8inch 2GB . 400 mAh is what I am aiming for but higher would be ok also. I measured my battery and it is roughly 20mm x 37mm x 4mm . I am asking anyone for places where they got or know to find a battery my size or fits my player. Since all IPOD NANO replacment battery sizes are different or because they don't show the batteries dimensions, I am asking for anybodys help . Thank you in advance.
Old 7th Dec 2006, 12:51 am
Default Re: what batteries fit in Super I-Platinum 1.8inch 2GB
silent-type , i've searched eBay sometime back and seems like only the iPod Shuffle battery fits. Not very sure about the iPod Nano, but some listings does have the dimensions listed too.
Or else, you could go down to your local hobby shop and they probably might have li-po batteries for your size.
Old 12th Dec 2006, 11:14 am
thanks lattesurf for the info. found a shuffle battery that will fit.
thanks again
8GB MP4 Super Nano 3 1.8inch Video Player clackers91 General Discussion 5 8th Mar 2007 4:29 pm
I have a Super i-Platinum from uxcell.com Da_smashman Mods and Themes 2 1st Feb 2007 4:38 am
i-Platinum/Super i-Platinum/Baby Nano/i-Platinum Junior? nanocopyuser General Discussion - Uxcell.com 1 17th Jan 2007 12:27 am
Full Metal Platinum 1.8inch 1GB - Volume? AmNite General Discussion 0 15th Jan 2007 8:32 am
New Super i-platinum Dragar General Discussion 9 24th Dec 2006 5:55 am
