[solved] "failed to set f-mode, maybe write-lock....&qu
Old 7th Dec 2006, 4:10 am
Default [solved] "failed to set f-mode, maybe write-lock....&qu
:wink: Hi ppl
Im kinda new on this "firmware modding" and I've never done anything like it, but i was curious because i've seen some cool mods done to some Iclones and i thought that i could do it myself, but unfortunably i can't
This is the player that i bought. only 512mb, cause i really dont need more, and it works fine. but when i try to backup the dump file using s1fwx this happens:
It looks kinda dumb, but i think my player doesnt come with a read/write lock feature, or does it?
Can someone give me a tip or something?
Bye and TY :lol:
Old 7th Dec 2006, 4:25 am
Tracanas, Have a look on your player at Settings>Firmware Version, what version is your firmware?
Also go to Settings>Online mode and make sure it is set to Normal only.
Old 7th Dec 2006, 4:29 am
tadad1 :
ACTS16D_13
2005/06/01
ws-3.2.16
2005/07/28
BTW, explain what ive just wrote :P
----Ahahaha----
Old 7th Dec 2006, 5:00 am
Tracanas, Basically your firmware is version 3.2.16 which should extract without any problems. Try connecting your player and holding down the play button while you run s1fwx to extract.
Old 7th Dec 2006, 5:06 am
Nop... still cant. ive checked the online mode, tried the 3 modes, pressing the play button, nothing. is there any other way to extract the firmware from the player?
----Ahahaha----
Old 7th Dec 2006, 6:27 am
ok, situation solved.
The problem was that when s1fwx searched the drives, my floppy disk (that i dont even have phisically :P) was creating a conflict. turned it off and its done. Thanks anyway and im sure that i will continue posting in here!
----Ahahaha----
Old 10th Dec 2006, 12:33 am
ah i normaly get the f mode problem when i have my player on hold
" Read or write device information failed!" wlazio2000 Dead Players 11 4th Apr 2009 5:41 am
Help. Read or Write device information failed XoLoX Dead Players 2 20th Oct 2007 11:38 pm
"Read or Write device information failed" serp Dead Players 22 8th Aug 2007 12:57 am
Read or write device information failed!Please exit the... Pissy Dead Players 2 6th Dec 2006 3:44 pm
[solved] removable disk busy, write-lock is activated lilikopter Dead Players 3 18th Jun 2006 2:31 am
