rockchip mp4 player -- questions!
Old 7th Jan 2007, 4:13 pm
I have a Rockchip mp4 too and the screen is the exactly same. But it seems that I can't fit the SD card into it. =/
弱々しいカルヴァン
Old 7th Jan 2007, 4:15 pm
Also, my player is hacked.
弱々しいカルヴァン
Old 7th Jan 2007, 6:11 pm
Default Re: rockchip mp4 player -- questions!
My Rockchip player takes miniSD not SD. If there is a slot in the side of the unit, then it will take miniSD cards. You have to push it in until it "clicks" into place then it should be visible under the SD card memory in the explorer.
Old 5th Feb 2007, 5:27 am
Originally Posted by ryanrudolf";p=&quot View Post
hey guys! first of all, very nice and informative site. i really wanted to buy an MP3 player, and through careful consideration and with the help of ur site, i decided to buy this:
I got the 1GB version and it works like a charm. I followed the steps in this site to make sure that the memory is not hacked, and fortunately it isnt. I was able to use the full capacity of the device and im really happy! I do have a few questions, and i think it has not yet been discussed in this forum. Hope someone can help me or point me to the right direction. here goes:
1] I believe that this is based in the Rockchip and the latest version of s1fwx (ver3.0/3.1) cannot detect it yet. Any other way(s) on how to modify the themes? Hello I have firmeware dated 2007-01-03 version 00.00.006
2] I loaded it with MP3s, but the ID3 tags do not appear. I tried ID3v1 but it only displays the Artist info. I tried ID3v2 and it displays gibberish info. I deleted all the tags and it just displays the filename. I was able to make the ID3 tags work on a "nano" look alike by using ID3v1, but on this particular MP4 i am stuck. Any ideas?
3] I found out that the player doesnt support AMV, only AVI encoded with xvid. The AVConverter1.0 supplied in the CD and AVIConverter2.1 supplied in this site both works. But i found out that if the source video is not MPG, eg(ASF), it will encode it properly but the playback on the player has distorted sound. Any ideas about this?
4] According to the manual, I can record live FM broadcasts, but I cant! I go to FM mode, then press and hold the A button as described in the manual, but nothing happens. Any ideas?
5] It has expandable memory, but it didnt specify what kind. Is it MMC or SD or miniSD?
I am really happy with this player. I managed to hook it up on my stereo component and its awesome!
Thanks again and have a merry christmas!
Some questions to my new player fabulouspaul General Discussion 6 12th Feb 2009 10:09 am
Some questions about a MP6 Player FunkySonicO Support and How To 1 18th Dec 2008 4:52 am
[QUESTIONS] Mp4 Player Touch RockChip -Blade- Support and How To 2 2nd Aug 2008 7:23 am
Few Questions about an MP4 Player sambobnz General Discussion 1 30th May 2007 5:51 am
My New 2G MP4 Player Questions. mp4L Support and How To 4 26th Jul 2006 9:29 am
