swan project?
Old 27th Dec 2006, 10:58 pm
Default swan project?
the swan project looks like what i need but will it be available on nano clones running 9.0.48 firmware??
Old 27th Dec 2006, 11:30 pm
pmilladcs, It was initially being designed for ATJ2085 chipsets as they were the most common but who knows what it will end up running on. The project has been going on for over 12 months and I am not sure how much progress has been made but I doubt it will be anytime soon before we start seeing any beta or early releases.
Old 27th Dec 2006, 11:55 pm
i'm guessing i dont have a ATJ2085 chipset right?
My 2Pac main menu
Old 28th Dec 2006, 12:08 am
pmilladcs, Not if you are running 9.0.XX series firmware, your player would have an ATJ2091, 2095, 2097 or CTW500.
Old 29th Dec 2006, 6:06 pm
mines running 9.0.50 firmware
chipset is ATJ2093H
flash is Samsung K9G8G08U0M (1GB)
its exactly the same as your pic
Old 30th Dec 2006, 5:42 am
Default Re: swan project?
i have a sumvision kpac 2gb with mini sd slot which is a rockchip player with version 00.00.0032 fw
a software project mmendozaf General Discussion 3 21st Feb 2009 1:02 pm
what exacly is the swan project? pmilladcs General Discussion 1 25th Dec 2006 12:57 am
this is me project siyah theme (buda benim projem siyah) whyliving Mods and Themes 1 10th Nov 2006 12:48 pm
Customized outer skin idea- Nano design project Gordon Mods and Themes 1 24th Jul 2006 4:20 am
My newest project Evolis2k2 Mods and Themes 12 18th Jun 2006 10:04 am
