Re: I finally got my Chipod! First impressions.
Hi Mate,
Yes the Nono (Nano) battery should fit, according to a thread in another section (Support and how to)it has been done, which is why I decided to search out some betteries and do it too!! Just have been comparing Ebay scammers..... err I mean sellers :oops: I was kinda thinkin too that there must be better than 330 mAh but the only ones to suit the clone are the Nono betteries anything else is way to big to fit into the SMALL space that houses the factory bettery. One Ebayer has a 400 mAH for sale BUT for some reason I had a spazm in my gut saying.... RIP OFF. If you check out the pix of the betteries you will notice thay have a fold over thin card that has some spec written on it, it seems a little sus in one 400 mah add. I may be very very wrong, also another guy which I emailed about this fact, and low and behold the whole add changed on the ebay web page :P ,, stating the right mAh rating Ebay (A place for big ripoff merchants ) Just a few words of warning hope it helps Joffa |
I don't know how you're finding sellers on eBay that have the Nano clone battery. A search for "nono" on eBay came up empty. Even on UXCELL, it only showed a power charger, not a battery. However, I noticed UXCELL has batteries for the Nano that go up to 900mAh (its $11US for this model). Not sure if this is suitable for a Nano -clone- though:
http://www.uxcell.com/uxcell/retail/...06031700ux0007 Quote:
Hi Mate,
I need to apologize :oops: I refer to nono as a little sarcasm towards the the whole Apple Ipod industry. It is not a brand of bettery, = (better battery) I only refer to nono as NO NO :shock: Search for ipod batteries on ebay again and you may have better luck word of advise, anything other than "suited for Nano" is way to big to fit into the clone space, UNLESS you can compare exact dimensions in your clone and the battery you may be buying. roughly 40mm x 22mm x 4mm. I think the 40mm length may be just enough for an actual Nano battery. My battery is somewhat shorter in length @ about 37mm Sorry Cheers Joffa |
| All times are GMT -7. The time now is 10:25 pm. |
