I finally got my Chipod! First impressions.
Old 6th Jan 2007, 2:10 pm
Default Re: I finally got my Chipod! First impressions.
Hi Mate,
Yes the Nono (Nano) battery should fit, according to a thread in another section (Support and how to)it has been done, which is why I decided to search out some betteries and do it too!! Just have been comparing Ebay scammers..... err I mean sellers ops:
I was kinda thinkin too that there must be better than 330 mAh but the only ones to suit the clone are the Nono betteries anything else is way to big to fit into the SMALL space that houses the factory bettery. One Ebayer has a 400 mAH for sale BUT for some reason I had a spazm in my gut saying.... RIP OFF. If you check out the pix of the betteries you will notice thay have a fold over thin card that has some spec written on it, it seems a little sus in one 400 mah add. I may be very very wrong, also another guy which I emailed about this fact, and low and behold the whole add changed on the ebay web page :P ,, stating the right mAh rating
Ebay (A place for big ripoff merchants )
Just a few words of warning
hope it helps
Joffa
White Super i Platinum 2 GB
Logic Chip
ATJ 2093 H
F8200FA 59E
LKD 9702 01
2006 - 10 - 25
FW 9. 0. 48
2006 - 9 - 12
Memory
Samsung 640
K9LAG08U0M PCB0 FEI848AX
Battery 3.7v 180 mAh
USB 2.0 A to Hirose 4 pin flat
Old 6th Jan 2007, 2:29 pm
I don't know how you're finding sellers on eBay that have the Nano clone battery. A search for "nono" on eBay came up empty. Even on UXCELL, it only showed a power charger, not a battery. However, I noticed UXCELL has batteries for the Nano that go up to 900mAh (its $11US for this model). Not sure if this is suitable for a Nano -clone- though:
http://www.uxcell.com/uxcell/retail/...06031700ux0007
Originally Posted by Joffa";p=&quot View Post
Hi Mate,
hope it helps
Joffa
Old 6th Jan 2007, 2:40 pm
Hi Mate,
I need to apologize ops: I refer to nono as a little sarcasm towards the the whole Apple Ipod industry. It is not a brand of bettery, = (better battery) I only refer to nono as NO NO :shock:
Search for ipod batteries on ebay again and you may have better luck
word of advise, anything other than "suited for Nano" is way to big to fit into the clone space, UNLESS you can compare exact dimensions in your clone and the battery you may be buying. roughly 40mm x 22mm x 4mm. I think the 40mm length may be just enough for an actual Nano battery. My battery is somewhat shorter in length @ about 37mm
Sorry
Cheers
Joffa
Logic Chip
ATJ 2093 H
F8200FA 59E
LKD 9702 01
2006 - 10 - 25
FW 9. 0. 48
2006 - 9 - 12
Memory
Samsung 640
Old 6th Jan 2007, 3:24 pm
Hi Mate,
Sorry
Cheers
Joffa
No problems, mate. All iI need are the dimensions, to find a suitable battery. If I find a "bettery" (better than 330mah) suitable for my nano clone, I'll let people here know.
Finally here! AMVConverter for Linux and Windows (FREE) alex2pb Video related 10 20th Jan 2008 7:40 pm
Receipt and first impressions of my first Glacier (2GB) michiganjfrog Reviews 27 10th Oct 2007 7:55 pm
Xilisoft MP4 Converter has finally turned ITS back snoopydoggy Video related 5 9th Oct 2007 1:50 am
i can finally get a new player! pmilladcs General Discussion - Uxcell.com 24 1st Apr 2007 10:54 pm
Finally a tool to backup 9.0.43 Firmware tadad1 Support and How To 39 30th Nov 2006 5:49 pm
