Car adapter for mp3/mp4 player?
Old 18th Jan 2007, 12:21 pm
Default Car adapter for mp3/mp4 player?
I would like one day to be able to hook up my mp4 (say, Glacier) to a car stereo, but I dont know much about the devices that allow you to do that. I know the "FM Transmitter" type is possible, but having experience with those cheesy FM Microphones.... I don't have any hope that transmitting audio on an FM band is going to yield clear, decent quality sound. Do you tune the radio on a certain frequency to get your mp3 audio? Are there alternatives to hooking up to your car stereo for players that do not have power jacks and must use the headphone output? Or are the FM transmitter type okay?
Old 18th Jan 2007, 12:46 pm
Default Re: Car adapter for mp3/mp4 player?
I use a rather simple FM transmitter on my mp3 player, mobile phone with mp3 player and even a real iPod video. The transmitter I have works well, but I used other transmitters and they are not good or even useless. The sound quality will be not so good, and the stereo effects will be gone to. A good option might be a radio with aux connection in the front. So you can connect any mp3 player with a 3.5mm connection to it. This will give a direct connection to the car radio with not quality loss.
Old 18th Jan 2007, 1:07 pm
I bought one for my daughter and it works fantastic!! Excellent stereo separation, volume,and tone quality. Just be sure to get one that tunes throughout the entire FM band so your sure to find a good blank spot on the FM spectrum.
Dave
Old 18th Jan 2007, 3:00 pm
Hotboxx/Avonik:
Thanks for the replies. Can you identify which FM transmitter you have or say where you got it from, so that I can get the exact same and know that I'm getting a good one?
Dave
Old 18th Jan 2007, 4:36 pm
I use the same as advertised here:
http://cgi.ebay.co.uk/FM-audio-transmitter-for-MP3-DVD-VCD-w-car-adaptor_W0QQitemZ190072362576QQihZ009QQcategoryZ86 535QQrdZ1QQcmdZViewItem
Old 18th Jan 2007, 11:13 pm
I have two types of FM transmitters.
They both work great. Both connect directly into the earphone jack of the player and plays directly on my car stereo.
The one with the holder is better because it plugs into your cigerette lighter and you click your player to is so stands it up quite nicely rather than laying down.
Old 18th Jan 2007, 11:29 pm
where did u get them from? especially the one for the cigarrette lighter. thats awesome.
oh no.....wait for it ..... here it comes..... i feel some shopping comin' on...
i want one!
Old 18th Jan 2007, 11:53 pm
The ones I have were imported by myself from a Chinese manufacturer. I've stopped doing them now.
My best bet is to look at eBay as they have a lot listed.
>> FM Transmitters on eBay <<
Hope that helps.
Old 19th Jan 2007, 8:45 am
thanks for the link.
why did you stop doing it?
if your not doing it any more, would you mind emailing me the manufacture you used?
i don't sell on ebay.
my email address is: ashley_rb@yahoo.com
(i've edited this post from the original because to many people were emailing me asking about what i wrote earlier)
Old 19th Jan 2007, 3:49 pm
Originally Posted by admin";p=&quot View Post
The ones I have were imported by myself froma Chinese manufacturer. I've stopped doing them now.
Hope that helps.
Yes it does! Thanks for all the links and pics. Looks like just what I was looking for...
Can't charge Glacier player with AC adapter or USB cable Shelley General Discussion - Uxcell.com 12 30th Jan 2007 3:36 pm
How to make a 2.5mm to 3.5mm adapter crazygazza Support and How To 2 15th Oct 2006 2:40 am
USB adapter Lorne Support and How To 1 11th Sep 2006 6:03 pm
