21st Jan 2007, 5:19 am
blubergeist , it seems bad. But it is very difficult to get any casing or parts for any player. Perhaps you could ask your seller if they sell the casing.
Another method would be to remove/cut out the old screen and fit a new screen. This can be done either by a glazier, or DIY with some thin clear plastics/glass (eg cd jewel case).
