firmware 9.0.40 for mp4 1gb 2gb TFT
Old 22nd Jan 2007, 1:20 am
Default firmware 9.0.40 for mp4 1gb 2gb TFT
I have this fw but i not know extract adn modify with s1res_v21 and s1fwx.
what i can make?
Old 22nd Jan 2007, 1:32 am
lupinvv , try using S1fwx v3.1 instead. It should be able to support your firmware version.
Old 22nd Jan 2007, 2:10 am
Default Re: firmware 9.0.40 for mp4 1gb 2gb TFT
connect to device 'F:\'...
init device...
set device to f-mode...
get info from device...
ic version = 0x0000
storage info = 0x0602, 0x0000, 0x0000, 0x0000
device = 'S1 Mp3 Player'
bootflash type = 'F285'
brom version = 3.0.80
firmware version = 9.0.50
read boot record...
detect firmware size...
error: Impossibile leggere dalla periferica specificata.
read flash...
write to file 'dump.bin'...
filename = 'dump.bin'
filetype = afi
md5 = 9F18F8326A05D4E059AFF2399B1AF9D2
file id = 'AFI '
vendor id = 0x6977
product id = 0x6552
version = 9.0.50
date = 00/00/0000
| BRECF285.BIN | | 16kb | | F285 | | B | | 8F33B1A6 |
| SYSINFO.BIN | | 192bytes | | | | | | 25DF23D9 |
filetype = unknown
disconnect from device...
success.
Old 22nd Jan 2007, 2:13 am
lupinvv , the message shows that your firmware is v9.0.50, not v9.0.40. The S1fwx only supports upto v9.0.43, anything above that and you will need to wait for future releases.
Old 22nd Jan 2007, 2:19 am
OPS.... :roll:
Excuse me...
