Audio Bitrate
Old 24th Jan 2007, 9:16 am
Default Audio Bitrate
I'm in the process of converting some audio recordings to MP3 so I can use them on my player, soon to arrive from UXcell. These are voice recordings of seminars only. Does anyone have a good idea what bitrate I should record at? I am truly a new arrival to this portable digital music medium. I know there are trade-offs between quality and size. There may also be limitations of the MP4 circuitry, for all I know. Any and all comments are welcome.
-Scott
Old 24th Jan 2007, 10:22 am
mykidsdad , you can set the audio bitrate to any that you prefer. Since it is speech only audio, i'll recommend anywhere between 48kbps to 64kbps. However, you can go lower, like 32kbps. But as you've said, it is a trade-off between quality and filesize. You can always encode at 32kbps and test on how it sounds on your computer.
So a typical 48kbps recording, for 10mins would result in a filesize of approx about 3.8MB.
While for music, generally you'll want to encode at least 128kbps or 192kbps.
Old 24th Jan 2007, 11:09 am
Default Re: Audio Bitrate
Thanks. If bitrates that low are good enough, that's all I need to know.
-Scott
Old 27th Jan 2007, 2:36 am
If you encode them as mono instead of stereo, it will cut the file size in half.
"Windows Update might require an update before you can install updates for Windows."
Old 29th Jan 2007, 6:06 am
Hello, if you encode mono you not get the size reduced by half, MP3 use something called "Joint Stereo" which means in only one channel the data for two channels are encoded. :P
Old 4th Feb 2007, 1:15 pm
impeeza is right. I was thinking of wav files ops:
DVD Audio ripping? ipodcraazzy2 Support and How To 0 18th Feb 2009 3:42 pm
Audio books Lorne General Discussion 5 21st Feb 2007 4:03 pm
Player Sets Bitrate to 0kbps MartinS General Discussion 3 1st Feb 2007 5:05 am
Changing MP3 Bitrate.. gtp300hp Support and How To 3 28th Jan 2007 9:18 am
audio problem NoInOi Support and How To 1 13th Sep 2006 11:55 pm
