-   -   MP4 1GB 1,2" what 's a model? (http://mympx.org/forum/general-discussion/36312-mp4-1gb-1-2-what-s-model.html)
jebaka 29th Jan 2007 10:29 am
what's a player? (model, producer, type)
front http://1.blurg.com/i/?022913300CT6597.JPG
before flash http://1.blurg.com/i/?033234100T6599b.JPG
after flash http://1.blurg.com/i/?097666600CT6599.JPG
rear http://1.blurg.com/i/?006715700CT6600.JPG
inside on rear side http://1.blurg.com/i/?088290700CT6601.JPG
number on board http://1.blurg.com/i/?040060100CT6602.JPG
baterry http://1.blurg.com/i/?088697700CT6604.JPG
inside on front side http://1.blurg.com/i/?007392300CT6605.JPG
yesterday i was flashed 3.2.16 firmware version and player was dead. i recovered it by shorting the pins (http://www.s1mp3.org/en/docs_deadrec.php)
and I upgrade firmware to 3.2.13 [-type_b_orig_3.2.13.7z Type B players 3.2.13 Rodrigo Lopes-] from this site http://www.s1mp3.org/en/downloads_fw.php.
now it's everything almost ok.... but can not control volume :( when i put button the volume straight away decreases till 'zero'
P.S.
sorry 4 my english.....
HELP ME!!!
jebaka 29th Jan 2007 10:56 am
MP3 Player firmware upgrading tool:
-Device name: S1 Mp3 Player
-Productor: Wilson Co. Ltd.
-Version: 3.2.13
lattesurf 29th Jan 2007 10:56 am
jebaka , you can try using waterlily to re-assign the volume button. However, not all firmwares work with waterlily, but give a try..
jebaka 29th Jan 2007 11:09 am
thanks for the help :) but......
not very I know how as this to make. and you do not know where to find this old software this marks [means] 3.2.13 with 2005/04/20?
I can record some other? only what...? because I do not know what the model.... there is not such HY-868
lattesurf 29th Jan 2007 10:47 pm
jebaka , the version number and date are not accurate. There could be thousands of variants of 3.2.13.
If you are able to solve the problem with waterlily, then just use this firmware. Or else, you can try other firmwares until you get a 100% compatible one. If the others do not work, you can still use back the old one.
jebaka 30th Jan 2007 12:41 am
I threw other soft 3.2.13 FM behither: http://www.mympxplayer.org/dload.php?action=category & cat_id=35 & sort_method=file_time & sort_order=DESC & the start=20 and again the player died :( on PRODUCT TOOL 4.19 I chose ERASE FLASH then the player turned out warm and began to stink..... burnt up some transistor (is visible on the photo) http://1.blurg.com/i/?073133300tr.JPG
I will seek and will try to connect... and how himself not thighs with difficulty one speaks :(
jebaka 5th Mar 2007 3:39 am
knows somebody what the element? just he burnt up
http://img65.imageshack.us/img65/8417/scalakez6.jpg
