upload does not change anything
Old 30th Jan 2007, 12:03 am
Default upload does not change anything
I have a 2GB "Ipod" Silver metal back and black plastic front 1.8" screen
F/W SRX_3.5.37 I have Dumped and repaired the F/W
With a COPY of the original firmware i changed the opening, hibernate, and ending sequence of my ChiPod
I have then saved it (overwriting the COPY) then i loaded it with the firware update Tool Ver. 4.09
it completed Successfully as read on the update tools status window
and the ChiPod rebooted then i unpluged it after "safely" removing it
but when i powered it back on...
There was No change EXCEPT for the chinese and the split format
which i already fixed
->WHY ARE THE PICTURES NOT CHANGING? <- actual question is here
Old 30th Jan 2007, 12:31 am
Ace_of_Ages, Can you upload the dump to www.uploaded.to and leave a link so I can have a squizz. My initial thought is that some firmware can have double ups of things like startup and menu images. Sometimes when a firmware is updated or modified by the manufacturers new images can be introduced and the coding changed but more oftern than not the old images are left behind. Sloppy programming really. Most firmware will even contain game images for games that are not even included or activated on the player. And sometimes secondary images can exist for different language settings. The long and the short of it you may have updated images that are not used.
Try also loading the firmware again with an earlier version of the update tool say 3.68 or 4.0. My understanding from the illegible Google Chinese translation is that the update tool in 4.09 was updated slightly for the newer chipsets and newer version firmware.
Old 30th Jan 2007, 12:43 am
http://uploaded.to/?id=d50dcp
The link is listed above to my partially updated skinn
what i am trying to do is enable the startrk theme that i got from this site
i figure that would be an easy first attempt
do i need to mess with any coding to let it know i changed pics?
Old 30th Jan 2007, 1:03 am
GREAT NEWS...
ok well i did 2 things differently
I got new Update software 3.65
and i did not press the ok button when it said it was complete
before when i would hit ok the chipod would immediatly reboot
this time it froze for a minute and then it rebooted with the new start up theme
Old 30th Jan 2007, 1:06 am
THANX
I LOVE THIS SITE
how do i contribute to the s1 res its in german?
Old 30th Jan 2007, 2:28 am
Ace_of_Ages, i know I found the same problem, you could email "wiRe"at
:-wiRe@s1mp3.de-: and ask him.
Upload de Firmware alexbrx Dead Players 2 13th Jul 2009 5:29 pm
I need someone to theme my fw. It is 3.5.37.I will upload it tank0592 Mods and Themes 0 3rd Feb 2008 11:05 am
upload Portuga Support and How To 0 5th May 2007 11:26 pm
TELLBOOK UPLOAD ! Groovy Support and How To 0 2nd Dec 2006 9:12 am
i want to upload new games robinlolo Support and How To 1 5th Aug 2006 1:15 pm
