downgrading
Old 30th Jan 2007, 4:59 pm
Default downgrading
i have firmware 9.0.50 is it safe to downgrade to a lower firmware? i tried extracting it but its messed up.
Old 30th Jan 2007, 5:08 pm
HellNova, Changing firmware is never safe and if you brick your 9.0.50 you have practically zero chance of recovery at the moment.
Old 30th Jan 2007, 5:11 pm
Default Re: downgrading
i know its never safe and so i shouldnt do anything until better software comes out?
Old 30th Jan 2007, 8:26 pm
HellNova , yes, just enjoy your player as it is right now. You can't extract your firmware with the current S1fwx anyway.
Old 30th Jan 2007, 8:34 pm
no i cant because it doesnt work properly
Old 30th Jan 2007, 8:51 pm
HellNova , if that's the case, if it is still under warranty, get it replaced with the seller.
Old 30th Jan 2007, 9:17 pm
HellNova, What problems are you having with your player?
Old 31st Jan 2007, 12:38 pm
my problem is that i used s1fwx exactly like everyone said(knowlodge base) and it wont let me moddify it properly it wont load in s1res
Old 31st Jan 2007, 11:28 pm
HellNova , the S1fwx does not support your version v9.0.50 at this moment, so you are unable to extract a working firmware dump.
Old 1st Feb 2007, 4:25 am
will i able to in a couple months
Downgrading? Edutainment Mods and Themes 1 30th Sep 2007 8:32 pm
need help updating/downgrading firmware sswajeta Support and How To 5 3rd Jan 2007 11:50 pm
Downgrading firmware on a chipod Lez General Discussion 2 26th Dec 2006 3:39 am
