Full Charged wont turn on
Old 2nd Feb 2007, 1:57 pm
Default Full Charged wont turn on
my mp3 player that looks like an ipod nano it works good sometimes but then it just automatcally turn off. Then i try to turn it on and it just stays black sometimes it shows the hour glass and then the screen gets darker and darker and just turns off any one know what is wrong
Old 2nd Feb 2007, 2:01 pm
Que Que is offline
Maybe your charger isn't working or the battery is dead. Does the player work when you put it on the charger?
Old 2nd Feb 2007, 2:10 pm
Default Re: Full Charged wont turn on
the chargers works and the battery is full charged
Old 4th Feb 2007, 11:36 am
anyone want to help me our???????????????
Old 4th Feb 2007, 11:42 am
Hey, I have the same problem as you. What i think the problem is that the battery is just plain crap. Me and my brother both have the same problem and i have messed with my filmware and he hasnt. So it most likely is the battery. Go in e-bay and look for ipod shuffel batterys that are 300mah and buy one of those and replace your battery if you have soldering skills. thats what im planing on doing
Old 4th Feb 2007, 11:45 am
kobeskool , does it function properly when connected via usb?
What happens when you unplug the usb? Does it show the symptoms you described?
Old 4th Feb 2007, 1:43 pm
the usb connector works
when i listen to music it works and then the screen just keep fading out untill it turns off but it wont turn on after that.
Old 5th Feb 2007, 12:00 am
kobeskool , it could likely be a battery problem or the circuit involving the power regulation.
If it is still under warranty, i'll suggest you contact your seller for an exchange.
WTH..my player wont turn on NEEDHELP_PLZ Dead Players 0 18th Oct 2008 7:52 pm
How To Know When ChargeD? *Dre@m* Support and How To 2 21st May 2008 2:30 am
wont detect it...i cannot charge it and cant turn it on leelaah Dead Players 5 4th Dec 2007 10:07 am
[solved] The battery is not charged full! Yusko Support and How To 5 30th Sep 2006 6:34 am
My Mp3 wont turn on??? RedXbox500 Dead Players 1 19th Jun 2006 4:30 am
