Charging 3.6v Lithium Ion Battery?
Old 6th Feb 2007, 4:41 am
Default Charging 3.6v Lithium Ion Battery?
Hello there,
I've S1 type mp4 player & it has 3.6v Li-Ion Battery. I want my mp4 player to last as long as it can. I heard that the way or pattern in which we charge the battery determines the life span of the battery. So, guys how should i charge my battery.
Whenever the battery indicator on the screen of the player is low,i charged battery until it is full. And it is also charging when I use the player as USB drive.
Is my charging process ok? or do i have to charge it after it has totally discharge?
Your any kind of info help my mp4 player to have long life.
Best Regards,
Buts101
Old 6th Feb 2007, 4:57 am
buts101, try to avoid running the battery flat, full cycle charges tend to stress the battery. Lots of quick topup charges is the best.
Old 7th Feb 2007, 5:57 am
Default Re: Charging 3.6v Lithium Ion Battery?
Hello there,
if my lithium give away, what should i do? where should i find the exact lithium batter? Can it be replaced?
Best Regards,
Buts101
Old 7th Feb 2007, 6:52 am
buts101, You should expect 2 to 3 years from your battery depending on usage when it comes time to replace it there are a few sellers on ebay.
http://cgi.ebay.com/Lithium-Battery-...QQcmdZViewItem
Depending on what style player you have and the amount of battery space you can also use iPod replacement batteries.
only the image connected and the battery charging pheonix1 Support and How To 2 26th Jun 2008 12:35 pm
help with the charging of battery for my mp4 raweclaz Support and How To 2 23rd Apr 2008 8:02 pm
battery charging vietnamesetan Support and How To 7 27th Feb 2007 2:47 pm
took 24hr to fully charging the battery sarden General Discussion 2 15th Feb 2007 4:21 am
Lithium Battery deepakrr General Discussion 5 1st Jan 2007 5:53 am
